Issue setting up ASA 5510 L2L
Having errors connecting a simply L2L VPN between Linksys and the 5510. will attach running config and debug files. Any input would be helpful.
Ron
Silver
Re: Issue setting up ASA 5510 L2L
This is bug ID: CSCsb82618
Do you have 7.1 Version?
See on : http://www.cisco.com/en/US/docs/security/pix/pix71/release/notes/pixrn711.html
Dharmesh Purohit
Silver
You can see all are error massage on below url:
http://www.cisco.com/en/US/docs/security/asa/asa70/system/message/logsev.html
Dharmesh
Looks like I am running version 7.0(6) new out of the box. I could download the latest Image however it looks like I will forego using my two SSL license's that I was going to test with :(
Ron
After updating to asa 7.2 I am getting this error from debug cmd debug crypto isakmp
Aug 28 23:40:20 [IKEv1]: IP = 69.137.178.185, Removing peer from peer tab
le failed, no match!
Aug 28 23:40:20 [IKEv1]: IP = 69.137.178.185, Error: Unable to remove PeerTblEnt
ry
Ron
Green
Ron,
Would you mind posting a clean config from the ASA?
I contacted Tac and was able to figure out that the Linksys VPN side of the tunnel was not routing back through the tunnel correctly. I have since wiped the Linksys configuration and reconfigured it with successes.
regards,
Ron
162
