Community Member
ISSUE with DMVPN and mutiple IVRF ASR1000
hello everyone,
I have a design with dmvpn where the hub is a router asr 1000 with public static IP addres and the spokes with ADSL, the spokes are branch office of  different clients (A y B), and I configured VRF in the HUB for separate the networks,  in the hub I  configured diferent tunnel for each client with  their VRF.
the DMVPN configuration is ok in  HUB and in SPOKES.,  the issue is that only work for one tunnel,  when  shutdown one tunnel in the HUB, the other tunnel get UP,  and backwards.
do you have any idea for that it happens ??
this is the design
thanks all
1 ACCEPTED SOLUTION
This is a very generic problem we need more details - is it tunnel interface status that goes down or IPsec goes down or no NHRP mappings are possible?
I think it's best you open a TAC case to investigate.
M.
M.
Community Member
the interface tunnels ip up in the mapping, the problem is that only one mapping of NHRP is up of the one spoke, when turn down this interface tunnel in the hub for this sopke, the other spoke goes up at the mapping nhrp and eigrp..
I check that in the phase 2 ipsec the encryption is one-way direcction in one vpn when the two interfaces tunnel is UP
thanks
Community Member
Hi Acruzgreq,
i do have the same Issue like you. On an Cisco C886VA-W-E-K9 the configuration is working without any problems. But not an ASR 1001 and ASR 1002. Do you get any response from TAC so far?
regards Ed
Community Member
Hi Eberhard,
can you attach the configuration that is  testing?
thanks
Community Member
Re: ISSUE with DMVPN and mutiple IVRF ASR1000
Hi Acruzqreg,
the config below is the one which is working on an 886 and not on the ASR (same config even the ip addresses).
ip vrf blue
rd 6207:20
ip vrf red
rd 6207:10
crypto isakmp policy 20
encr 3des
authentication pre-share
group 2
crypto isakmp policy 30
crypto isakmp key XX address 19.24.132.14
crypto isakmp invalid-spi-recovery
crypto isakmp keepalive 60 5
crypto ipsec transform-set red esp-null esp-sha-hmac
mode tunnel
crypto ipsec transform-set blue esp-aes esp-sha-hmac
mode tunnel
crypto ipsec fragmentation after-encryption
crypto ipsec profile redProfile
set transform-set red
set pfs group2
crypto ipsec profile blueProfile
set transform-set blue
set pfs group2
interface Loopback10
description user-net
ip vrf forwarding red
ip address 10.102.179.173 255.255.255.240
no ip redirects
no ip proxy-arp
ip tcp adjust-mss 1400
shutdown
interface Loopback20
description Mgmt Net
ip vrf forwarding blue
ip address 10.108.78.61 255.255.255.252
no ip redirects
no ip proxy-arp
interface Tunnel0
description DMVPN red
bandwidth 10000
ip address 10.255.255.20 255.255.255.0
no ip redirects
no ip proxy-arp
ip mtu 1388
ip nhrp authentication dmvpn
ip nhrp map multicast dynamic
ip nhrp map 10.255.255.1 19.25.132.164
ip nhrp map multicast 19.25.132.164
ip nhrp network-id 100
ip nhrp holdtime 300
ip nhrp nhs 10.255.255.1
ip nhrp server-only
ip nhrp registration no-unique
ip tcp adjust-mss 1348
tunnel source GigabitEthernet0/0/0
tunnel mode gre multipoint
tunnel key xx
tunnel path-mtu-discovery
tunnel protection ipsec profile redProfile
interface Tunnel1
description DMVPN blue
bandwidth 10000
ip address 10.0.17.10 255.255.192.0
no ip redirects
no ip proxy-arp
ip mtu 1360
ip nhrp map 10.0.0.1 19.25.132.174
ip nhrp map multicast 19.25.132.174
ip nhrp network-id 101
ip nhrp nhs 10.0.0.1
ip nhrp server-only
ip tcp adjust-mss 1320
tunnel key xx
tunnel protection ipsec profile blueProfile
interface GigabitEthernet0/0/0
description uplink
ip address 10.108.77.13 255.255.255.248
negotiation auto
router bgp 6207
bgp router-id 10.0.17.13
bgp log-neighbor-changes
address-family ipv4 vrf blue
redistribute connected
neighbor 10.0.0.1 remote-as 65421
neighbor 10.0.0.1 description *** eBGP_Peering_blue ***
neighbor 10.0.0.1 password 7 xxx
neighbor 10.0.0.1 timers 10 30
neighbor 10.0.0.1 activate
neighbor 10.0.0.1 route-map Drop_All_Prefix_In in
neighbor 10.0.0.1 route-map Prefix_Out_blue
exit-address-family
address-family ipv4 vrf red
neighbor 10.255.255.1 remote-as 65421
neighbor 10.255.255.1 description *** eBGP_Peering_red ***
neighbor 10.255.255.1 password 7 xxx
neighbor 10.255.255.1 timers 10 30
neighbor 10.255.255.1 activate
neighbor 10.255.255.1 route-map Drop_All_Prefix_In in
neighbor 10.255.255.1 route-map Prefix_Out_red
exit-address-family
ip route 0.0.0.0 0.0.0.0 10.108.77.9
ip route vrf blue 0.0.0.0 0.0.0.0 10.0.0.1
ip route vrf red 0.0.0.0 0.0.0.0 10.255.255.1
ip prefix-list MGT description
ip prefix-list MGT seq 10 permit 10.108.78.0/25 le 32
ip prefix-list No-Route description Reject all Routes
ip prefix-list No-Route seq 10 deny 0.0.0.0/0 le 32
ip prefix-list red_NET description Downstream TF-Hotspot-Range
ip prefix-list red_NET seq 10 permit 10.102.123.0/24 le 32
ip prefix-list red_NET seq 20 permit 10.102.161.0/25 le 32
ip prefix-list red_NET seq 30 permit 10.102.179.0/24 le 32
ip prefix-list red_NET seq 40 permit 10.102.163.0/24 le 32
ip prefix-list red_NET seq 50 permit 10.102.180.0/24 le 32
route-map Drop_All_Prefix_In permit 10
description Due to Static Routing deny any incoming Routes
match ip address prefix-list No-Route
route-map Prefix_Out_red premit 10
match ip address prefix-list red_NET
route-map Prefix_Out_blue permit 10
description propagate MGT
match ip address prefix-list MGT
ASR--1#sh dmvpn
Legend: Attrb --> S - Static, D - Dynamic, I - Incomplete
        N - NATed, L - Local, X - No Socket
        # Ent --> Number of NHRP entries with same NBMA peer
        NHS Status: E --> Expecting Replies, R --> Responding, W --> Waiting
        UpDn Time --> Up or Down Time for a Tunnel
Interface: Tunnel0, IPv4 NHRP Details
Type:Spoke, NHRP Peers:1,
# Ent  Peer NBMA Addr Peer Tunnel Add State  UpDn Tm Attrb
     1 19.25.132.164    10.255.255.1  NHRP 00:39:23     S
Interface: Tunnel1, IPv4 NHRP Details
     1 19.25.132.174        10.0.0.1    UP 00:39:23     S
The tunnel goes in NHRP state after 30 seconds.
regards
Eberhard
Community Member
your config is very similar to tha I test, on my ASR not support 2 diferent Ipsec profiles (I dont know why), I configured one shared profile separating the key with fqdn. I hope that this its a problem with IOS an that can resolve.
I share the config that work for me, I hope that this help.
crypto keyring cisco
  pre-shared-key hostname branch.branchA.com key keyA
  pre-shared-key hostname cpe_maqueta_vpn2.branchB.com key keyB
crypto isakmp policy 10
encr 3des
group 2
lifetime 14400
crypto isakmp profile cisco
   keyring cisco
   self-identity fqdn
   match identity host domain branchA.com
   match identity host domain branchB.com
   initiate mode aggressive
crypto ipsec transform-set cisco esp-3des esp-sha-hmac
mode transport
crypto ipsec profile cisco
set transform-set cisco
set isakmp-profile cisco
interface Tunnel11
YOUR CONFIG
tunnel protection ipsec profile cisco shared
interface Tunnel12
YOUR CONFIG
Community Member
Hi Acruzgreg,
thanks for your config.
I solved the problem with mine.
It is not possible to have the same tunnel source interface in both tunnels.
OLD
interface Tunnel0
interface Tunnel1
Changed to>>>
interface Tunnel0
interface Tunnel1
tunnel source lo10
and then the NHRP is not failing anymore.
regards
eb
Community Member
Great,
I will test with this config,
thanks,,,
1227
