Java problem within FW MC (VMS 2.2)
when accessing, from FW MC, the "Configuration ==> Setting ==> SNMP" option, I got the following error messages if my PIX config SNMP-SERVER LOCATION" parameter includes an ampersand character (& character) :
You have encountered an ERROR!
ERROR - The request attribute command is processSetting - The request attribute target is null - The custom msg is -
The application error is Nested exception during invocation of processSetting on the target com.cisco.nm.mdc.pix.units.Snmp
The exception is java.lang.NullPointerException
The exception message is null
The exception type is : java.lang.NullPointerException
The exception message is : null
(Other java esoterical messages follows)
If I remove the ampersand character from the SNMP-SERVER LOCATION parameter i.e. :
snmp-server location PARIS S R (instead of
snmp-server location PARIS S&R ),
the problem disapears
This problem appears with VMS 2.2 and VMS 2.2 Update 1
1 REPLY
Re: Java problem within FW MC (VMS 2.2)
What version of firewall MC are you running specifically? I'm running 1.2.2 and I simply get a pop-up window telling me not to enter special characters, then it takes me back to the config screen.
Updates for Firewall MC (and all the other MC's can be found here):
http://www.cisco.com/kobayashi/sw-center/cw2000/vms-planner.shtml
I don't know of a specific bug fix for this (checked the Releae Notes for both 1.2.1 and 1.2.2 and there's nothing related), but there is a lot of Java fixes on both versions so the update probably fixes this issue just by fixing some Java issues. Try the update and see how you go.
179
