L2L VPN problem between 2 routers
please find the attached file for the routers configuration.
i need to make a vpn tunnel through the internet between 2 routers (R1&R2) in two different sites.
For R1 site
- LAN Network : 192.168.1.0 /24
- users can access the internet properly.
- The Router is configured by ISP engineers to build the internet connection
For R2 site
- LAN Network : 192.168.2.0 /24
-The Router is configured by ISP engineers to build the internet connection.
After that when i tried to configure the 2 routers for the vpn , i found that the vpn cannot established.
Troubleshooting
- i cannot ping any server from site1 to site2
- the output of " sh crypto isakmp sa " on R1 & R2 is :
R1#sh crypto isakmp sa
dst src state conn-id slot status
please i need your help.
waiting your replies.
regards
1 REPLY
Re: L2L VPN problem between 2 routers
hi
u have a common mistake
u need to exmpt the vpn traffic from get nated
do the following on router 1
and the same on the opesit way on router2
no access-list 1 permit 192.168.1.0 0.0.0.255
access-list 101 deny ip 192.168.1.0 0.0.0.255 192.168.2.0.0
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
then make ur nating as following
no ip nat inside source list 1 pool net overload
ip nat inside source list 101 pool net overload
on router 2 do the same idea but ur ACL shoult looks like
from 192.168.2.0 to 192.168.1.0 to be denoed from get nated as above
after u do that clear nating table or save ur config and reload the router
good luck
hope this helps
106
