Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
lan to lan vpn between ASA and 7200 router
Hi Friends,
I need to setup lan to lan vpn between ASA(at the remote location) and 7200 router(in our network).
<7200 router (IP Add: 10.10.5.2)>------------------(Internet)------------------<(IP Add: 192.168.12.2) ASA(5510)>---- 192.135.5.0/24 network
I'm going to have the following configuration:
7200 router:
crypto isakmp policy 80
enc des
auth pre-share
group 1
lifetime 3600
crypto isakmp key cisco123 address 192.168.12.2
cryto ipsec transform-set VPNtrans esp-des esp-md5-hmac
crypto map VPNTunnel 80 ipsec-isakmp
set peer 192.168.12.2
set transform-set VPNtrans
match address 110
int fa0/0
ip add 10.10.5.2 255.255.255.192
ip virtual-reassembly
no ip route-cache
speed 100
duplex full
access-list 110 permit ip any 192.135.5.0 0.0.0.255
ASA:
int e0/0
nameif inside
security-level 100
ip add 192.135.5.254 255.255.255.0
int e0/1
nameif outside
security-level 0
ip add  192.168.12.2 255.255.255.240
access-list ACL extended permit ip 192.135.5.0 255.255.255.0 any
route outside 0.0.0.0 0.0.0.0.0  192.168.12.3 1
isakmp policy 10 auth pre-share
isakmp policy 10 enc des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 3600
crypto ipsec transform-set VPNtran esp-des esp-md5-hmac
crypto map VPN 10 match address ACL
crypto map VPN 10 set peer 10.10.5.2
crypto map VPN 10 set transform-set VPNtran
tunnel-group 10.10.5.2 type ipsec-l2l
tunnel-group 10.10.5.2 type ipsec-attributes
pre-shared key cisco123
crypto map VPN interface outside
isakmp enable outside
dhcpd address 192.135.5.1-192.135.5.250 inside
dhcpd dns 172.15.4.5 172.15.4.6
dhcpd wins 172.15.76.5 172.15.74.5
dhcpd lease 14400
dhcpd ping_timeout 500
dhcpd enable inside
please verify the configuration, please correct me if I missed something. I'm into a critical situation right now...
Please advise...
Thanks a lot...
1 ACCEPTED SOLUTION
Re: lan to lan vpn between ASA and 7200 router
Where is it failing at the moment?
Can you share output of after trying to establish the VPN tunnel:
show cry isa sa
show cry ipsec sa
Please also run the following debug to see where it is failing:
debug cry isa
debug cry ipsec
1 REPLY
show cry isa sa
show cry ipsec sa
debug cry isa
debug cry ipsec
258
