LAN2LAN VPN problem
Hi all
I am configuring a LAN 2 LAN VPN between 2 routers.
but on my side of the connection, i have
an unusual design,
the interesting traffic from my side from the VPN is the same IP range that is being used on router's Outside interface.
Assume that the REAL ip on the router is x.x.x.1, the interesting traffic has a source addresses x.x.x.1, x.x.x.2, x.x.x.3 ....
And on the other side (which i dont have access two, it does have the normal usual setup)
The config on my router is:
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
crypto isakmp key MMBB#STC@33 address z.z.z.233
crypto ipsec security-association lifetime seconds 28800
crypto ipsec transform-set encryption esp-3des esp-md5-hmac
crypto map intelligit 10 ipsec-isakmp
set peer z.z.z.233
set transform-set encryption
match address 120
interface FastEthernet0/0
description Connected to internet
ip address x.x.x.42 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description Connected to LAN-SWITCH
ip address 192.168.0.220 255.255.255.0
ip nat inside
duplex auto
speed auto
ip route 0.0.0.0 0.0.0.0 x.x.x.41
ip http server
no ip http secure-server
ip nat translation timeout 5
ip nat pool ogero x.x.x.43 x.x.x.43 netmask 255.255.255.248
ip nat inside source list 100 pool ogero overload
logging history warnings
access-list 100 permit ip 192.168.0.0 0.0.0.255 any
access-list 120 permit ip host x.x.x.42 host v.v.v.66
access-list 120 permit ip host x.x.x.43 host v.v.v.66
access-list 120 permit ip host x.x.x.44 host v.v.v.66
The Phase 1 is still not going up, the "Debug crypto isakmp" shows the info in the attached file
1 REPLY
Re: LAN2LAN VPN problem
This is the debug output
110
