Nat 0 for Inside and Outside translations on ASA5520
We have a nat 0 (inside) acl-nonat config statement that defines an acl to not nat internal 10 networks to specific external networks. In addition, we have remote VPN connections that terminate on the ASA5520, and we need to have the 10 networks at the remote sites not nat to external networks as well.
My questions are:
1) Can I setup a "nat 0 (outside) acl-nonatremote" command to nonat these remote users?
2) Can a nat 0 (inside) aclxx1 coexist with a nat 0 (outside) aclxx2?
3) Will implementing the nat 0 (outside) command cause an outage during the implementation or will it be a transparent change? (i.e. some nat acl's must be removed and reapplied to allow them to take affect in the correct order).
Any feedback would be appreciated.
-Scott
1 ACCEPTED SOLUTION
Re: Nat 0 for Inside and Outside translations on ASA5520
Hi Scott,
Don't worry, you are on the right track. Just one more thing, if you have a "global (inside) 10", then you would need to add the inside subnet/ network in the acl-remotenonat as destination.
Kamal
Hi Scott,
1) Yes you can setup the "nat (outside) 0 acl-nonatremote" but you need it only if you have something like "nat (outside) 1 0.0.0.0 0.0.0.0".
2) Yes it can coexist.
3) It will not cause any outage but please make sure that you do need it.
Kamal
Hi Karnal,
Below is what I currently have in place for nats, which is why I requested using a second nonat 0 for the outside interface with a separate, unique acl for the remote users who don't require nating to external addresses. So the order that the acl's are applied has an affect, except nat 0 which always applies first. That is why my inquiry to have another nat 0, but have it apply to the outside interface. In this scenario though, the acl would only source the remote vpn 10 subnets and not the whole 10/8 range:
Existing nat definitions:
nat (inside) 0 access-list nonat
nat (inside) 5 access-list wirelessnat
nat (outside) 10 access-list remotenat
nat (inside) 15 access-list dynnat
Existing acl's and order of function:
access-list nonat line 1 extended permit ip 10.0.0.0 255.0.0.0 10.0.0.0 255.0.0.0
truncated
access-list wirelessnat line 2 extended permit ip 10.1.19.0 255.255.255.0 any
truncated
access-list remotenat line 2 extended permit ip 10.1.57.0 255.255.255.0 any
truncated
access-list dynnat line 2 extended permit ip 10.0.0.0 255.0.0.0 any
truncated
The reason for the separate nat (inside) option is because I segragate the public nat ip's that each acl affects
In theory I should be able to use the existing nat 0 statement, and just apply it with the "outside" command and corrolate a separate acl to it for the remote user subnet. So the changes would include the following:
nat (outside) 0 acl-remotenonat
access-list acl-remotenonat line 2 extended permit ip 10.1.57.0 255.255.255.0 198.217.36.0 255.255.255.0
truncated
As I shared, in this case I would use the nat 0 command, but apply it to different interfaces (inside vs outside), and use different acl's for each.
I don't believe I can use a nat (outside) <0 because I cannot apply deny statements to any other nat acl's except nat 0.
What do you think?
-Scott
Two corrections on my last post:
1) I meant to say my the changes are additions to the existing configuration.
2) I meant to say I can't use a nat (outside) >0 because...(I said less that 0 and meant greater than 0).
Thanks!
Hi Scott,
It seems that the VPN clients pool is 10.1.57.0 and the clients are accessing the internet through this device. Is the network behind this device 198.217.36.0/24? If yes then, your thought is absolutely correct. The commands would be as following :
nat (outside) 0 access-list acl-remotenonat
Hope this helps,
Kamal
Thanks Kamal,
To clarify, my remote vpn users that terminate on the asa use 10.1.57.0. They access internal and internet sights.
For the external sights, they nat out a unique public addy. There are however other specific external sites like 198.217.36.0 that the remote users need to access without natting.
My goal is to use the nat (outside) 0 acl-remotenonat acl to achieve that request.
At the same time though, the nat (inside) 0 acl-nonat will continue to function for inside users connecting to the same 198.217.36.0 sites without natting (these currently work now).
I will be attempting this later tonight. Thanks again for your input.
-Scott
Hi Scott,
Kamal
I applied a nat (outside) 0 acl remote-nonat to the existing configuration that has a nat (inside) 0 acl nonat and it worked. Thank you for the advice and the help!
-Scott
317
