NAT to internal hosts problem when connected through VPNSSL
I have configured a VPNSSL on a Cisco 877. I am trying to access a internal LAN segment from users connected to context CONS. I am doing NAT overload to interface VLAN, and I can ping the VLAN interface itself, but not internal hosts.
Here is my config for interfaces, context and NAT:
interface Virtual-Template1
description $FW_INSIDE$
ip unnumbered Vlan199
no ip redirects
no ip proxy-arp
ip nat outside
ip virtual-reassembly
end
interface Vlan199
ip address X.X.X.240 255.255.255.0
ip nat inside
end
ip nat inside source route-map NAT_C interface Vlan199 overload
route-map NAT_C permit 10
access-list 10 permit 192.168.63.0 0.0.0.255 log
ip local pool Pool_Cons 192.168.63.1 192.168.63.10
webvpn context cons
secondary-color white
title-color #669999
text-color black
ssl authenticate verify all
policy group policy_1
   functions svc-enabled
   svc address-pool "Pool_Cons"
   svc keep-client-installed
   svc split exclude local-lans
   svc split exclude X.X.X.201 255.255.255.255
virtual-template 1
default-group-policy policy_1
aaa authentication list ciscocp_vpn_xauth_ml_3
gateway gateway_1 domain cons
max-users 5
inservice
Any idea? Tried to configure myself and through Cisco CP, but no way to make it work.
Thanks in advance.
Everyone's tags (4)
296
