bsc
Need Help in understanding IPSEC/ISAKMP debug messages
I am checking some debug messages and fell over the ones below (sorry for the long debug).
What really puzzles me, is that the router builds a new ISAKMP and then a little time later he tears it down again.
Nov 24 12:23:12.017: ISAKMP: set new node 374015275 to QM_IDLE
Nov 24 12:23:12.081: ISAKMP:(0:1:HW:2):deleting node 374015275 error FALSE reason "QM done (await)"
Nov 24 12:23:12.081: ISAKMP:(0:1:HW:2):Node 374015275, Input = IKE_MESG_FROM_PEER, IKE_QM_EXCH
Nov 24 12:23:12.081: ISAKMP:(0:1:HW:2):Old State = IKE_QM_R_QM2 New State = IKE_QM_PHASE2_COMPLETE
Nov 24 12:24:02.082: ISAKMP:(0:1:HW:2):purging node 374015275
To me with my limited IPSec experience this looks like a problem, but it works fine and the SAs look fine.
Does anyone have a pointer on what's going on or a link to a document, that explains it?
-birgit
1 REPLY
Re: Need Help in understanding IPSEC/ISAKMP debug messages
Would suggest to use this link to decode out out the exact meaning for the logged lines ...
http://www.cisco.com/cgi-bin/Support/Errordecoder/index.cgi
regd
649
