Community Member
Need Help
use static route between 3750X_Main and ASA
only 10.2.101.0/24 permit access internet
10.2.101.222 connect to 3750X_Main
ASA_Config
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address 222.202.222.99 255.255.255.0
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.2.101.203 255.255.255.0
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
name-server 202.106.0.20
domain-name default.domain.invalid
same-security-traffic permit intra-interface
object network INSIDE_OUTSIDE
subnet 10.2.101.0 255.255.255.0
host 10.2.101.203
object network WEB_SERVER
host 10.2.101.222
object network VPN_CLIENT
subnet 10.2.80.0 255.255.255.0
object network VPN_LOCAL
subnet 10.0.0.0 255.0.0.0
object-group network VPN_REMOTE
network-object 10.2.77.0 255.255.255.252
access-list 101 extended permit ip any any
access-list split extended permit ip 10.0.0.0 255.0.0.0 any
ip local pool VPN_CLIENT 10.2.80.1-10.2.80.254 mask 255.255.255.0
no nat (inside,outside) source dynamic VPN_LOCAL INSIDE destination static VPN_REMOTE VPN_REMOTE
no nat (outside,outside) source dynamic VPN_CLIENT INSIDE destination static VPN_REMOTE VPN_REMOTE
no nat (outside,inside) source static VPN_REMOTE VPN_REMOTE destination static VPN_LOCAL VPN_LOCAL
no nat (outside,inside) source static VPN_CLIENT VPN_CLIENT destination static VPN_LOCAL VPN_LOCAL
nat (inside,outside) dynamic interface
nat (inside,outside) static interface service tcp 4000 4000
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 222.202.222.97 1
route inside 10.2.12.0 255.255.255.0 10.2.101.254 1
route inside 10.2.13.0 255.255.255.0 10.2.101.254 1
aaa authentication ssh console LOCAL
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map DYNMAP 1 set ikev1 transform-set ESP-3DES-MD5
crypto dynamic-map DYNMAP 1 set reverse-route
crypto map OUTSIDEMAP 1 ipsec-isakmp dynamic DYNMAP
crypto map OUTSIDEMAP interface outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 28800
telnet 0.0.0.0 0.0.0.0 inside
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh timeout 30
ssh version 2
console timeout 0
management-access inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
group-policy VPN_CLIENT internal
group-policy VPN_CLIENT attributes
vpn-tunnel-protocol ikev1
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split
address-pools value VPN_CLIENT
username cisco password 3USUcOPFUiMCO4Jk encrypted
username cisco attributes
vpn-group-policy VPN_CLIENT
tunnel-group DefaultL2LGroup ipsec-attributes
ikev1 pre-shared-key *****
tunnel-group VPN_CLIENT type remote-access
tunnel-group VPN_CLIENT general-attributes
default-group-policy VPN_CLIENT
tunnel-group VPN_CLIENT ipsec-attributes
tunnel-group-map default-group DefaultL2LGroup
nameif outside
security-level 0
As shown above
1.EzVPN_Client can access L2L_PC
2.EzVPN_Client can access 10.2.101.0/24
3.EzVPN_Client can not access 10.2.12.0/24&10.2.13.0/24
4.10.2.12.0/24&10.2.13.0/24 can access L2L_PC,but once L2L_PC access 10.2.12.0/24&10.2.13.0/24,     10.2.12.0/24&10.2.13.0/24 can not access L2L_PC.
5.between 10.2.101.0/24 and L2L_PC can access together any time.
why? need help.
124
