Community Member
NEED URGENT SOLUTION
Here is the scenario:
I have tunnels to HO from all BO(Hub and spoke)
A-- HQ
B- BO
C--B0
A-B tunnel down, A-C tunnl up,B-C tunnel up.
Now I want to send the traffic B-C-A thru VPN tunnel is it possible.
I dont hve a time give the brief info. pl. do the needfull.
Thanks in advance.
sateesh
Re: NEED URGENT SOLUTION
Yes is is possible.
YOu need to amned your VPN acls' your no-nat acls then configure same security intra feature.
HTH>
Community Member
Thanks for your immdeiate resonpse.
A-HQ
B-BO
C-B0
Could you pl. brief What changes need to done at B,C,A.
A network is
172.16.1.0
B network is
192.168.1.0
C Network is
192.168.2.0
pl. do the needfull. Traffic should pass trgh B-C-A
regards
sateesh
117
