Pb Connection VPN client with Pix 515E v7.0! please help me
I have the cisco vpn client v4.6.02(in USA) and a pix 515Ev7(France).
I create a VPN remote access(with vpn wizard, ASDM v5.0 ) and it's no Ok. When i connect with the client i have on the pix Log this message :
-Removing peer from peer table fail, no match
- Error : unable to remove PeerTblEntry
Please help me
I give you my conf, What is my error :
ftp mode passive
access-list Outside_access_in extended permit tcp any host 81.192.X.W eq smtp
access-list Outside_access_in extended deny ip any any
access-list inside_nat0_outbound extended permit ip any 192.168.39.240 255.255.255.248
access-list Outside_cryptomap_dyn_20 extended permit ip any 192.168.39.240 255.255.255.248
ip local pool vpnpool 192.168.39.240-192.168.39.245 mask 255.255.255.0
nat-control
global (Outside) 1 interface
global (DMZ) 1 192.168.40.20-192.168.40.50 netmask 255.255.255.0
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 192.168.38.0 255.255.255.0
nat (inside) 1 192.168.39.0 255.255.255.0
nat (DMZ) 1 192.168.40.0 255.255.255.0
static (inside,DMZ) 192.168.40.0 192.168.39.0 netmask 255.255.255.0
static (DMZ,Outside) 81.192.X.W ISVW netmask 255.255.255.255
static (inside,DMZ) SRV-MAIL SRV-MAIL netmask 255.255.255.255
static (inside,Outside) 81.192.X.Y 192.168.38.220 netmask 255.255.255.255
access-group inside_access_in in interface inside
access-group Outside_access_in in interface Outside
access-group DMZ_access_in in interface DMZ
route inside 192.168.31.0 255.255.255.0 192.168.39.254 1
route inside 192.168.38.0 255.255.255.0 192.168.39.254 1
route Outside 0.0.0.0 0.0.0.0 Router 1
group-policy QQQQQQ internal
username admin password xxx encrypted privilege 15
username user password xxx encrypted privilege 0
username user attributes
vpn-group-policy QQQQQQ
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto dynamic-map Outside_dyn_map 20 match address Outside_cryptomap_dyn_20
crypto dynamic-map Outside_dyn_map 20 set transform-set ESP-DES-SHA
crypto map Outside_map 65535 ipsec-isakmp dynamic Outside_dyn_map
crypto map Outside_map interface Outside
isakmp enable Outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp nat-traversal 20
isakmp ipsec-over-tcp port 10000
tunnel-group QQQQQ type ipsec-ra
tunnel-group QQQQQQgeneral-attributes
address-pool vpnpool
default-group-policy QQQQQQ
tunnel-group QQQQQQ ipsec-attributes
pre-shared-key *
telnet 192.168.38.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.39.252-192.168.39.254 inside
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable inside
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect http
service-policy global_policy global
Re: Pb Connection VPN client with Pix 515E v7.0! please help me
Hi Marza
I just gone through your config sample and found missing the interface configuration.
I would also suggest to refer this link for more info and also post the interface config.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800949fb.shtml
regds
Hi Marza
I found by myself that
not works if you define the source as any if you want to define source for every ip addresses remove the following line from your config or if you want to connect to your pix from a specified ip address then define the source in your access list ,it was my problem that i solved it in this way.
Thanks.
Hope to helpful.
remember rate the useful post.
Best Regards Bahman Mozaffari
211
