PIX Issue - Seperate Networks, Same IP Addressing Scheme
PIX Firewall
Need to create new site-to-site VPN where the new remote site's has the same, internal network IP addressing scheme as an existing VPN already setup on the PIX.
Possible workaround...
Define unique traffic down to the host level for each location.
Thanks in advance for any ideas!
Re: PIX Issue - Seperate Networks, Same IP Addressing Scheme
this is a common problem
use the 'Alias' command or destination NAT
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094aee.shtml
there are many documents about it on this site
Gold
i doubt that the workaround is not possible, even you restrict the traffic down to host level. for example, 192.168.1.4 (local) tries to communication with 192.168.1.5 (remote), however, the local host would consider that is on the same subnet and wouldn't pass traffic to the pix.
one possible solution is to organise an extra nat service from your isp. it should work as we've exactly the same issue before and now is solved.
hope this helps
202
