Community Member
PIX reset to factory default(activation key problem)
Hi,all
I have a query regarding cisco pix firewall.If I reset the pix firewall to factry default then i have to again activate the ur licence or not?I mean i have to again enter the activation key or not.
1 ACCEPTED SOLUTION
Re: PIX reset to factory default(activation key problem)
Hi sandeep,
I have encountered a activation key issue when changed the IOS, but have never seen factory defaults cause this. If you worry about that, issue sh ver and note your activation key down, in case it asks.
1 REPLY
Hi sandeep,
344
