Community Member
Problem DMZ to Inside and Inside to DMZ
Dear Expert,
Now i have problem, i use ASA 5510 and i have interface inside,outside and DMZ and i would like DMZ can access into inside and Inside can access into DMZ, and the both can access outside(Internet).now it have problem it cannot access ..
Please see configuration in the attach file.
Best Regards,
Hall of Fame Super Blue
Re: Problem DMZ to Inside and Inside to DMZ
Hi Rechard
Please see Wan Routing & Switching forum where i have posted an answer.
Jon
Community Member
Kindly add the following commands and clear xlate and clear conn
static (inside,dmz) 192.168.3.0 192.168.3.0 netmask 255.255.255.0
access-list dmz extended permit ip 192.168.4.0 255.255.255.0 192.168.3.0 255.255.255.0
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
firewall is statuful, traffic from dmz to inside will allow by above mention static command and access-list on dmz interface and vice versa
you also removed this You internet will work. No need of this command.
static (dmz,inside) 192.168.3.0 192.168.4.0 netmask 255.255.255.0
global (dmz) 1 interface.
132
