Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Problem establishing SSL
In the vpn concentrator, I have installed the SSL Client (sslclient-win-1.0.2.127.pkg), and generated the ssl certificate by the certificate management configuration. The Vpn has already the 4.7.2 version.
When I try to install the ssl vpn client for webvpn, it shows me the certificate but shows too a message: "The SSL Vpn Client is unable to establish a connection".
And in the logs of the vpn concentrator shows: User [user] Group [Base Group] disconnected:
Session Type: WebVPN
Duration: 0:13:47
Bytes xmt: 61
Bytes rcv: 244
Reason: Port Error
Carolina
1 REPLY
Silver
Re: Problem establishing SSL
Since the problem can be due to many things, could you send me a debug :
In menu 'Configuration | System | Events | Classes' setup the
following classes with 'Events to Log' set to severities 1-13:
WEBVPN
SSL
STC
Go to 'Monitoring | Filterable Event Log' and get the logs for all classes, all severities.
Conduct a test and collect the debug
297
