Problem routing traffic between two VPN tunnels
Attach you can find a picture with our network topology.
The problem I have is that I cannot reach network 10.201.64.0 (R3) from 192.168.2.0 (R2), but it works perfectly from R1
As you can see from the attached picture traffic from R2 to R3 goes through R1.
All traffic source ip addressed to 10.201.64.0 is first translated to 10.202.64.1 and then sent to 10.201.64.0 network.
ping R2 -> R3 (100% loss)
ping 10.201.64.1 source 192.168.2.1
PING 10.201.64.1 (10.201.64.1) from 192.168.2.1 : 56(84) bytes of data.
--- 10.201.64.1 ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 3999ms
ping R1 -> R3 (100% success)
ping 10.201.64.1 source 192.168.100.1
Sending 5, 100-byte ICMP Echos to 10.201.64.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.100.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 44/45/48 ms
ping R1->R2 (100% success)
ping 192.168.2.1 source 192.168.100.1
Sending 5, 100-byte ICMP Echos to 192.168.2.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 12/12/12 ms
ping R2->R1 (100% success)
ping 192.168.100.1 source 192.168.2.1
PING 192.168.100.1 (192.168.100.1) from 192.168.2.1 : 56(84) bytes of data.
--- 192.168.100.1 ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4048ms
rtt min/avg/max/mdev = 4.576/5.677/6.277/0.721 ms
As you can see only packet flow from R2 to R3 doesn't work.
R1: cisco config:
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp policy 20
encr aes
group 2
crypto isakmp policy 30
encr aes 256
group 5
crypto isakmp key XXXXXXXXXXXXXXXXXXXXXX address 94.xxx.xxx.58
crypto isakmp key XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX address 193.xxx.xxx.243
crypto isakmp keepalive 3600
crypto ipsec transform-set vpn-transform esp-aes esp-sha-hmac
mode transport
crypto ipsec transform-set vpn-transform-aes esp-aes esp-sha-hmac
mode tunnel
crypto map cisco 11 ipsec-isakmp
description Tunnel to 94.xxx.xxx.58
set peer 94.xxx.xxx.58
set transform-set vpn-transform
match address 100
crypto map cisco 12 ipsec-isakmp
description Tunnel to Hermes
set peer 193.xxx.xxx.243
set security-association lifetime kilobytes 2560
set transform-set vpn-transform-aes
set pfs group5
match address 102
interface GigabitEthernet0/0
description $ES_LAN$$ETH-LAN$
ip address 192.168.100.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/1
description $ETH-WAN$
ip address 193.xxx.xxx.220 255.255.255.192
ip nat outside
duplex auto
speed auto
crypto map cisco
ip nat pool METRONET 193.xxx.xxx.220 193.xxx.xxx.220 netmask 255.255.255.192
ip nat pool HERMES 10.202.64.1 10.202.64.1 netmask 255.255.255.252
ip nat inside source route-map HERMES_RMAP_1 pool HERMES overload
ip nat inside source route-map SDM_RMAP_1 pool METRONET overload
ip route 0.0.0.0 0.0.0.0 193.xxx.xxx.193
ip route 192.168.1.0 255.255.255.0 192.168.100.254
ip route 192.168.222.0 255.255.255.0 192.168.100.254
ip sla auto discovery
access-list 100 remark CCP_ACL Category=4
access-list 100 remark IPSec Rule
access-list 100 permit ip any 192.168.2.0 0.0.0.255
access-list 101 remark CCP_ACL Category=18
access-list 101 remark IPSec Rule
access-list 101 deny   ip any 192.168.2.0 0.0.0.255
access-list 101 deny   ip any 10.201.64.0 0.0.0.255
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 permit ip 192.168.100.0 0.0.0.255 any
access-list 101 permit ip 192.168.222.0 0.0.0.255 any
access-list 102 remark CCP_ACL Category=4
access-list 102 remark IPSec Rule for Hermes VPN
access-list 102 permit ip 10.202.64.0 0.0.0.255 10.201.64.0 0.0.0.255
access-list 103 remark CCP_ACL Category=18
access-list 103 remark Hermes VPN NAT rule
access-list 103 deny   ip 10.202.64.0 0.0.0.255 10.201.64.0 0.0.0.255
access-list 103 permit ip any 10.201.64.0 0.0.0.255
route-map HERMES_RMAP_1 permit 1
match ip address 103
route-map SDM_RMAP_1 permit 1
match ip address 101
Re: Problem routing traffic between two VPN tunnels
Hi Herman!
I have a few questions to ask you though?
Are you trying to do a site to site or you wanting to do a DMVPN? That's what this topology seems like to me. I mean if you have direct internet connection from R2 and R3, My suggestion would be do it directly on then rather than going via R1.
You might need to implement some routing and if so I'll suggest you do DMVPN where by R1 is the hub while R2 & R3 are spoke to R1. At least to the best of my knowledge that should work.  Here are some resource for DMVPN configs below that might help you.
http://www.cisco.com/en/US/docs/solutions/Enterprise/WAN_and_MAN/DMVPN_A.html
http://www.fir3net.com/Cisco-Router/dmvpn-tutorial.html
http://blog.ine.com/2008/08/02/dmvpn-explained/
The sites where you have R2 and R3 I believe they both have different ISP? just saying from the ip address scheme you indicated.
Another scenario is that you probably want to do have a site btw R1, R2, R3 where both R2 & 3 are accessing resource from R1. That's a different ball game all together.
I hope this helps out though!
Have a good one.
Cheers
Teddy
Hi Teddy,
To answer your questions first:
Q: Are you trying to do a site to site or you wanting to do a DMVPN?
A: DMVPN
Q:The sites where you have R2 and R3 I believe they both have different ISP?
A: Yes, they are on different ISPs
R2->R3 vpn is not possible.
Consider R1 as a main company router
R2 is a branch office router
R3 is router on a vendor side.
The goal is to access network 10.201.64.0 from 192.168.2.0 (R2->(R1)->R3).
This currently doesn't work and I don't know why
This is exactly what i want to achieve except that I am using nat
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a0080093dc8.shtml
Cheers
Herman
361
