Problem running DMVPN and IPSec VPN at the same time
I have a hub-spoke VPN network: 2 hub routers are 7206 VXR and remote routers are 2800. Each hub router has had number of point-to-point IPSec+GRE tunnels configured and running with remote sites. I'm now adding DMVPN between each hub router and a few other remote sites. The DMVPN is running fine between hub and spokes, but somehow it caused all the eixsting point-to-point IPSec tunnels drop. Here are some details:
1) Hub DMVPN config:
crypto isakmp key MYKEY address 12.12.12.12
crypto ipsec profile DMVPN
set transform-set DM
interface Tunnel1
no ip redirects
ip mtu 1400
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 600
tunnel source G0/0
tunnel mode gre multipoint
tunnel protection ipsec profile DMVPN
router eigrp 1
no passive-interface Tunnel1
2) Spoke DMVPN config:
crypto isakmp key MYKEY address 14.14.14.14
interface Tunnel1
ip address 192.168.1.2 255.255.255.0
ip mtu 1400
ip nhrp map 192.168.1.1 14.14.14.14
ip nhrp map multicast 14.14.14.14
ip nhrp nhs 192.168.1.1
tunnel source G0/0
tunnel destination 14.14.14.14
3) When DMVPN is up, hub router existing IPSec tunnels are shown ISAKMP failure.
Hub# show crypto isakmp sa
14.14.14.14     20.20.20.20 MM_NO_STATE       1508    0 ACTIVE (deleted)
4) After I shut down interface Tunnel1, existing IPSec tunnels are coming back. ISAKMP SA shows QM_IDLE state.
Have anyone seen similar issues between DMVPN and traditional point-to-point IPSec+GRE tunnels on the same router?
Thanks a lot
462
