Problem to establish L2L Static-to.dynamy VPN between ASA5520 and 877
I need help to solve a problem to establish VPN connection between ASA5520 and router 877.
this is the configs
ASA Configuration
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 86400
crypto ipsec security-association lifetime kilobytes 4608000
crypto ipsec fragmentation before-encryption management
crypto ipsec fragmentation before-encryption Inside
crypto ipsec fragmentation before-encryption Outside
crypto ipsec df-bit copy-df management
crypto ipsec df-bit copy-df Inside
crypto ipsec df-bit copy-df Outside
crypto dynamic-map dynmap 19 set transform-set myset
crypto dynamic-map dynmap 19 set security-association lifetime seconds 86400
crypto dynamic-map dynmap 19 set security-association lifetime kilobytes 4608000
crypto map mymap 40 ipsec-isakmp dynamic dynmap
crypto map mymap interface Outside
isakmp identity hostname
isakmp enable Outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
tunnel-group L2L type ipsec-l2l
tunnel-group L2L ipsec-attributes
pre-shared-key *
peer-id-validate req
Router Configuration
crypto isakmp policy 20
encr 3des
hash sha
group 2
crypto isakmp key ****** address x.x.x.x
crypto map mymap 15 ipsec-isakmp
set peer x.x.x.x
match address VPN
add the debug crypto isakmp and debug crypto ipsec
  • VPN
1 REPLY
Silver
Re: Problem to establish L2L Static-to.dynamy VPN between ASA552
LAN-to-LAN IPsec tunnel between two Cisco Secure PIX Firewalls. Each PIX Firewall has a private protected network behind it. This concept also applies when you translate subnets instead of individual hosts.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008022f99e.shtml
120
