Problem to establish vpn site2site between vpn concentrator3000 and pix
I need help in solving the issue with vpn connectivity between site to site with vpn concentrator 3000 and pix 501.
We have a static ip at the concentrator end(Central Site) and dynamic ip at the pix side which is the Remote site. Pix is configured for vpn with pre-shared key and the problem is how do we assign the same transform-set at the concentrator side for the vpn to form. Also is the issue of assigning an IKE peer address in LAN-to-LAN ipsec as the remote end is having dynamic ip. How do I go about it??
1 REPLY
Bronze
Re: Problem to establish vpn site2site between vpn concentrator3
The "transform-set" equivalent on the VPN 3000 is configured under;
Configuration | Tunneling and Security | IPSec | LAN-to-LAN | Add or Modify
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_1/config/tunnel.htm#1260355
In the figure 15-9, the options under "Authentication" and "Encryption" are used to define the transform sets, that is, how the user date will be authenticated and encrypted.
107
