Community Member
Problem with EZVPN on client offices
I have the following problem on configuring ezvpn for the following situation:
3 different locations - 1 HQ with 2901 server and 2 offices with 861 clients.
Clients connects to HQ, I do traffic between HQ and offices but I cannot ping between offices (ping from 192.168.1.0/24 to 192.168.2.0/24 and vice versa.
The configs:
Server:
aaa new-model
aaa authentication login default local
aaa authentication login vpn_xauth_1 local
aaa authorization exec default local
aaa authorization network vpn_group_1 local
username user@off1 password 7 121B0437171A19173D0A3C3D
username user@off2 password 7 0501071B3349684D1C2302200A3F140
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group off1
key qacRxxxxx
pool VPN_POOL_1
acl 110
save-password
max-users 1
netmask 255.255.255.0
crypto isakmp client configuration group off2
key z3sExxxxxx
pool VPN_POOL_1
acl 120
save-password
max-users 1
crypto isakmp profile isu-ike-profile-1
   match identity group off1
   match identity group off2
   client authentication list vpn_xauth_1
   isakmp authorization list vpn_group_1
   client configuration address respond
   keepalive 10 retry 2
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile isu_ipsec_profile1
set transform-set ESP-3DES-SHA
set isakmp-profile isu-ike-profile-1
interface GigaEthernet0/0
description $ETH-WAN$
ip address 10.xxx.xxx.xxx 255.255.255.xxx
ip nat outside
crypto map CRYPTO_MAP_1
interface GigaEthernet0/1
description $ETH-LAN$
ip address 10.0.0.1 255.255.255.0
ip nat inside
interface Virtual-Template1 type tunnel
ip unnumbered GigaEthernet0/0
ip flow ingress
ip nat inside
ip virtual-reassembly
tunnel mode ipsec ipv4
tunnel protection ipsec profile isu_ipsec_profile1
router rip
version 2
redistribute static
access-list 110 permit ip 10.0.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 permit ip 10.0.0.0 0.0.0.255 192.168.2.0 0.0.0.255
Client 1:
aaa new-model
ip dhcp pool localpool
   network 192.168.2.0 255.255.255.0
   default-router 192.168.2.1
   dns-server 193.231.252.1
   lease 0 2
crypto ipsec client ezvpn EZVPN_CLIENT_1
connect auto
group off1 key qacxxxxxxxxxxxxxxxxxx
mode network-extension
peer 10.xxx.xxx.xxx
username user@off1 password bxxxxxxx
xauth userid mode local
interface FastEthernet4
ip address 86.xxx.xxx.xxx 255.255.255.xxx
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex auto
speed auto
interface  Vlan 1
ip address 192.168.2.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip tcp adjust-mss 1452
duplex auto
speed auto
crypto ipsec client ezvpn EZVPN_CLIENT_1 inside
no ip address
ip nat inside
keepalive 10 3
ip route 0.0.0.0 0.0.0.0 FastEthernet4
Client 2:
Like the config for client 1 with other link ip, other group, user and pass and 192.168.1.0/24 as internal network
Thanks.
Hello Christian,
Checking on your configuration it looks like you are not allowing the communication between the two offices, since you are not including them in the ACLs.
For instance, the ACL 110 allows traffic from 10 to 1.0 but not from 2.0 to 1.0, please add this to your configuration, make sure your NAT rules do not affect this traffic on any of the Routers and then reset the EzVPN tunnel.
Let us know the results.
Thanks.
Community Member
Re: Problem with EZVPN on client offices
Thanks for your reply Javier.
I've added the access-lists from office networks but nothing's changed.
access-list 110 permit ip 10.0.0.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 110 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 110 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 permit ip 10.0.0.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 permit ip 192.168.2.0 0.0.0.255 192.168.2.0 0.0.0.255
sh ip access-lists
Extended IP access list 110
    20 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
    30 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
Extended IP access list 120
    30 permit ip 192.168.2.0 0.0.0.255 192.168.2.0 0.0.0.255
After modifying the access lists the tunnel from began to disconnect and reconnect with the frequency of 1 minute.
The message from the server:
%CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer at 86.xxx.xxx.xxx (ip of the client)
Thanks!
542
