Problem with ping in site-to-site
Hi, I have a tunnel vpn site-to-site with two ASA5505, the tunnel is up but when I try ping between inside lan I have in log file:
Teardown ICMP connection for faddr 192.168.0.100/0 gaddr 192.168.1.159/512 laddr 192.168.1.159/512
Built outbound ICMP connection for faddr 192.168.0.100/0 gaddr 192.168.1.159/512 laddr 192.168.1.159/512
My address space is:
private: 192.168.0.0/24 and 192.168.1.0/24
public: 2.1.44.35 and 1.2.182.42   (this address aren't really)
About vpn I have this configuration:
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object icmp
protocol-object icmp6
object-group protocol DM_INLINE_PROTOCOL_2
object-group protocol DM_INLINE_PROTOCOL_3
object-group icmp-type DM_INLINE_ICMP_1
icmp-object echo
icmp-object echo-reply
access-list outside_1_cryptomap extended permit ip 192.168.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list outside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 any 1.2.182.40 255.255.255.248
access-list outside_access_in extended permit object-group DM_INLINE_PROTOCOL_2 any host IP_FW
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 1.2.182.46 1
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set peer 2.1.44.35
crypto map outside_map interface outside
crypto isakmp enable outside
tunnel-group 2.1.44.35 type ipsec-l2l
tunnel-group 2.1.44.35 ipsec-attributes
and on the other side:
access-list inside_access_in extended permit ip 192.168.1.0 255.255.255.0 any
access-list outside_access_in extended permit tcp any host 2.1.44.36 object-group DM_INLINE_TCP_0
access-list outside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 any host FW
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.1.64 255.255.255.224
access-list inside_nat0_outbound extended permit ip 192.168.1.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list outside_1_cryptomap extended permit ip 192.168.1.0 255.255.255.0 192.168.0.0 255.255.255.0
global (outside) 1 interface
route outside 0.0.0.0 0.0.0.0 2.1.44.38 1
crypto map outside_map 1 set peer IP_PUB_CIS
crypto isakmp policy 10
no crypto isakmp nat-traversal
tunnel-group 1.2.182.42 type ipsec-l2l
tunnel-group 1.2.182.42 ipsec-attributes
Thanks.
Salvatore.
Re: Problem with ping in site-to-site
These syslogs do not indicate a problem, in fact they show that an ICMP connection is properly being built and being torn down again, which is normal.
So is the ping working or not?
I do spot one possible problem, you have:
but inside_access_in is not defined anywhere on the first ASA.
If that does not help and the ping still fails, check the syslogs and "show crypto ipsec sa" (to see if encrypt/decrypt counters are increasing) on both sides.
hth
Herbert
Hi, in debug I have:
#packet-tracer input outside icmp 192.168.1.159 8 0 192.168.0.100
action drop
drop reason: (rpf violated) reverse-path verify failed
In attach more information
I have verified more times the configuration but I have understood where is the error in my configuration, I have once again the configuration file for both side and the new  configuration is the following:
: Saved
ASA Version 8.2(1)
hostname ciscoasa
domain-name default.domain.invalid
enable password 0R2MX4Kk7jsue7zn encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.10 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 2.1.44.35 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa821-k8.bin
ftp mode passive
dns server-group DefaultDNS
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 1.2.182.42
crypto map outside_map 1 set transform-set ESP-3DES-SHA
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:7b17d4ebbb0e9b605d8f97458554eb46
: end
other side:
: Saved
ASA Version 8.2(1)
hostname ciscoasa
enable password yjWoTDJEsBZjH.DV encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.10 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 1.2.182.42 255.255.255.248
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
http 192.168.0.0 255.255.255.0 inside
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
pre-shared-key *
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
Cryptochecksum:f9eb6df8a212428a8871873099b98558
: end
Thanks.
Salvatore.
..pheraps the problem are the static route ? I always used vpn based on openswan and in the site-to-site configuration is needful the parameter:
leftnexthop=x.y.y.z
this ip address is the ip assigned to router.
In cisco ASA configuration I have:
route outside 0.0.0.0 0.0.0.0 1.2.186.46 1
where 1.2.186.46 is router ip address and
1.2.186.42
..is the ip address on wan interface of Cisco ASA.
Sorry but I cannot understand where I am wrong ! :-(
Thanks.
Salvatore.
Routing seems ok to me.
But as I mentioned already, can you please check "show crypto ipsec sa" on both sides, before and after trying a ping.
That should tell us where it is going wrong
Please also clarify from which side you were pinging, and on which side you took those packet-tracers earlier (and was that with the config from your original post or with the config from your previous post) .
I have done reset to factory default valuse and then I have made again all configurations (as the  last configuration I sent to forum) and now I do ping with success but unfortunately I understand why in the  first configuration I could not ping.
Thanks.
Salvatore.
1038
