Problem with PIX-PIX Fullmesh IPsecVPN
Scenario: Setup where in five different spoke locations use Full meshed PIX-PIX IPsec VPNs. Hub location(Mumbai) has a
PIX 525 UR with 6.3(4). Spoke locations have PIX-515E/PIX-525 with 6.3(4).
Problem Observed : One or two of the IP address subnets go unrechable in a IPsec tunnel when other subnets in the same tunnel are reachable.
Other observation:
** The Mumbai PIX CPU goes upto 95%
** IPsec session if cleared the problem resolves.
** PIX reboot also resolves the problem
Please suggest what the Root cause could be and the work around.
Pramila Sekar
1 REPLY
Re: Problem with PIX-PIX Fullmesh IPsecVPN
Have you tried to find out which process hogs off your CPU ?
Also did u try to shut any of the spoke location link and find out whether it goes back to the normal condition ?
any specific input inline with any CPU spikes at the remote spoke locations when you are into this situation ?
regds
94
