Problem with Site to Site VPN
I am trying to create a site to site VPN using a cisco 2901 and Linksys router.
I have the VPN configured and connected and I can ping gateway to gateway. However, from the Cisco I can't ping any of the devices beyond the gateway.
Example, from the cisco I can ping 192.168.5.254 (gateway IP address) source gig 0/1 and it works great.
However if I ping from the cisco 192.168.5.50 (end user PC) source gig 0/1 it doesn't work.
I have created a client VPN and that works perfectly.
Below is my config. Any help is greatly appreciated because I am stuck.
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
crypto isakmp policy 3
encr 3des
group 2
crypto isakmp key 1234567890 address 1.2.3.4
crypto isakmp keepalive 30 30
crypto isakmp nat keepalive 30
crypto isakmp client configuration group iptel
key 1234567890
pool SDM_POOL_1
acl remote
crypto isakmp client configuration group shortel
key 1234567890
pool SDM_POOL_2
acl shortel
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
crypto ipsec transform-set Linksys-IPSEC esp-3des esp-sha-hmac
crypto dynamic-map SDM_DYNMAP_1 1
set transform-set ESP-3DES-SHA
reverse-route
crypto map SDM_CMAP_1 isakmp authorization list sdm_vpn_group_ml_1
crypto map SDM_CMAP_1 client configuration address respond
crypto map SDM_CMAP_1 1 ipsec-isakmp
description Tunnel to Derek Linksys
set peer 174.52.250.198
set transform-set Linksys-IPSEC
match address shortel
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
interface Loopback0
ip address 1.1.1.1 255.255.255.0
ip virtual-reassembly in
ip policy route-map vpn
interface Embedded-Service-Engine0/0
ip address 10.10.10.5 255.255.255.0
interface GigabitEthernet0/0
ip address 4.3.2.1 255.255.255.248
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.24.62.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.62
encapsulation dot1Q 62
ip address 10.94.62.65 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.111
encapsulation dot1Q 111
ip address 192.168.17.1 255.255.255.0 secondary
ip address 192.168.15.1 255.255.255.0 secondary
ip address 10.1.1.1 255.255.255.0
ip nat inside
ip local pool SDM_POOL_1 172.16.2.50 172.16.2.99
ip local pool SDM_POOL_2 172.16.3.208
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static tcp 10.24.62.100 3389 interface GigabitEthernet0/0 33898
ip nat inside source static tcp 10.24.62.101 3389 interface GigabitEthernet0/0 33899
ip nat inside source route-map SDM_RMAP_1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 10.24.62.207 80 4.3.2.1 80 extendable
ip nat inside source static tcp 10.24.62.201 444 4.3.2.1 444 extendable
ip nat inside source static tcp 10.94.62.67 9080 4.3.2.1 9080 extendable
ip nat inside source static tcp 10.94.62.67 9082 4.3.2.1 9082 extendable
ip nat inside source static tcp 10.24.62.212 9080 4.3.2.1 80 extendable
ip nat inside source static tcp 10.24.62.212 9082 4.3.2.1 9082 extendable
ip nat inside source static tcp 10.24.62.204 20 4.3.2.1 20 extendable
ip nat inside source static tcp 10.24.62.204 21 4.3.2.1 21 extendable
ip nat inside source static tcp 10.24.62.204 22 4.3.2.1 22 extendable
ip nat inside source static tcp 10.24.62.204 80 4.3.2.1 80 extendable
ip nat inside source static tcp 10.24.62.204 443 4.3.2.1 443 extendable
ip nat inside source static 10.24.62.204 4.3.2.1 extendable
ip nat outside source static 4.3.2.1 10.94.62.65 extendable
ip route 0.0.0.0 0.0.0.0 4.3.2.1
ip route 10.8.8.0 255.255.255.0 Loopback0
ip route 172.16.2.0 255.255.255.0 Loopback0
ip route 192.168.5.0 255.255.255.0 Loopback0
ip access-list extended NAT
remark SDM_ACL Catergory=2
deny   ip 10.94.62.0 0.0.0.255 172.16.2.0 0.0.0.255
deny   ip 10.94.62.0 0.0.0.255 172.16.3.0 0.0.0.255
deny   ip 10.94.62.0 0.0.0.255 192.168.5.0 0.0.0.255
deny   ip 10.24.62.0 0.0.0.255 192.168.5.0 0.0.0.255
deny   ip 10.94.62.0 0.0.0.255 10.8.8.0 0.0.0.255
deny   ip 10.24.62.0 0.0.0.255 10.8.8.0 0.0.0.255
deny   ip 172.16.2.0 0.0.0.255 192.168.5.0 0.0.0.255
deny   ip 10.1.1.0 0.0.0.255 172.16.2.0 0.0.0.255
deny   ip 10.1.1.0 0.0.0.255 172.16.3.0 0.0.0.255
deny   ip 192.168.15.0 0.0.0.255 172.16.3.0 0.0.0.255
deny   ip 192.168.15.0 0.0.0.255 172.16.2.0 0.0.0.255
deny   ip 192.168.15.0 0.0.0.255 192.168.5.0 0.0.0.255
deny   ip 10.1.1.0 0.0.0.255 192.168.5.0 0.0.0.255
deny   ip 192.168.17.0 0.0.0.255 172.16.2.0 0.0.0.255
deny   ip 192.168.17.0 0.0.0.255 172.16.3.0 0.0.0.255
deny   ip 192.168.17.0 0.0.0.255 192.168.5.0 0.0.0.255
deny   ip 10.24.62.0 0.0.0.255 172.16.2.0 0.0.0.255
deny   ip 10.24.62.0 0.0.0.255 172.16.3.0 0.0.0.255
permit ip any any
ip access-list extended PointtoPoint
ip access-list extended remote
remark SDM_ACL Category=4
permit ip 10.94.62.0 0.0.0.255 any
permit ip 10.24.62.0 0.0.0.255 any
permit ip 10.1.1.0 0.0.0.255 any
permit ip 192.168.17.0 0.0.0.255 any
permit ip 192.168.15.0 0.0.0.255 any
ip access-list extended shortel
access-list 150 permit ip host 1.1.1.1 172.16.2.0 0.0.0.255
access-list 150 permit ip host 1.1.1.1 192.168.5.0 0.0.0.255
access-list 150 permit ip host 1.1.1.1 172.16.3.0 0.0.0.255
route-map SDM_RMAP_1 permit 1
match ip address NAT
route-map vpn permit 10
match ip address 150
set ip default next-hop 4.3.2.2
Everyone's tags (3)
1 REPLY
Hi Jon
you can have a look with the "show crypto" commands if the packets are transfered or if there are errors.
Have you tried it with a PC from the Gi0/1 to reach gateway and other office pcs?
Are the Gateways in the clients set proper?
651
