Problem with Split DNS
Ok i'll try to explain my best since English is my 2nd language
1) I have a working ASA 5505, vpn connection with Split Tunnel, which means that my clients can connect  at work and still access their local network
2) Problem I have is that atm they need to conect (exemple on RDP) with  the ip adress so 192.168.0.16
3) I would like to be able to rdp using  w7.domain.local instead of 192.168.0.16
4) I heard about the split-tunnel value domain.local but the problem is that  I need the VPN connection to add me a dns server adress and a search domain to be able to try to ping
5) I added manually the dns server IP and the search domain name on my mac and it still doesn't work)
6) The most important part  Since the local lan of the work office is 192.168.0.X and alot of people at home have 192.168.0.X we use Ip translation so to communicate exemple 192.168.0.16   I write 192.168.200.16 and I can access my PC at work
TL:DR version
I want my VPN connection to assign my VPN client this IP address 192.168.200.14 and the search domain domain.local
I want to be able to say from my VPN cleint ping w7.domain.local and that the Packet will pass threw the  Cisco as 200.16 then converts back to 0.16 and access my PC
Here is my Code, please note that i removed some confidential info, but the VPN connection is working ATM
IF you have any questions feel free to ask
ASA Version 8.2(1)
terminal width 250
hostname machine
enable password G0n/46uG1zueNp0y encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.0.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address X.X.X.X 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa821-k8.bin
ftp mode passive
access-list inside-out extended permit tcp host 192.168.0.2 any eq smtp
access-list inside-out extended deny tcp any any eq smtp
access-list inside-out extended permit ip any any
access-list inside-out extended permit icmp any any
access-list vpn-client-policy-nat extended permit ip 192.168.0.0 255.255.255.0 10.250.132.0 255.255.255.0
access-list VPN-SPLIT-TUNNEL standard permit 192.168.200.0 255.255.255.0
access-list 100 extended deny tcp 10.250.132.0 255.255.255.0 eq smtp 192.168.200.0 255.255.255.0 eq smtp
access-list 100 extended permit ip 10.250.132.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 100 extended permit icmp 10.250.132.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list 100 extended permit ip 10.250.132.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list 100 extended permit icmp 10.250.132.0 255.255.255.0 192.168.200.0 255.255.255.0
access-list outbound extended permit tcp host 192.168.0.2 any eq smtp
access-list outbound extended permit tcp host 192.168.0.10 any eq smtp
access-list outbound extended deny tcp any any eq smtp
access-list outbound extended permit ip any any
pager lines 34
logging enable
logging timestamp
logging buffered debugging
logging trap debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool mobilepool 10.250.132.100-10.250.132.130 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (outside,inside) 192.168.200.0 192.168.0.0 netmask 255.255.255.0
static (inside,outside) 192.168.200.0  access-list vpn-client-policy-nat
access-group outbound in interface inside
access-group outside-acl in interface outside
route outside 0.0.0.0 0.0.0.0 24.37.96.137 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 192.168.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set mobileset esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map dyn1 1 set transform-set mobileset
crypto dynamic-map dyn1 1 set reverse-route
crypto map mobilemap 1 ipsec-isakmp dynamic dyn1
crypto map mobilemap interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 inside
ssh 10.0.128.0 255.255.255.0 inside
ssh 10.250.132.0 255.255.255.0 inside
ssh 192.168.0.0 255.255.0.0 inside
ssh 192.168.0.0 255.255.255.0 outside
ssh timeout 5
ssh version 2
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy mobilegroup internal
group-policy mobilegroup attributes
vpn-simultaneous-logins 50
vpn-idle-timeout 2000
vpn-session-timeout 2000
split-tunnel-network-list value VPN-SPLIT-TUNNEL
split-dns value domain.local
group-policy mobile_policy internal
group-policy mobile_policy attributes
split-tunnel-policy tunnelspecified
tunnel-group mobilegroup type remote-access
tunnel-group mobilegroup general-attributes
address-pool mobilepool
default-group-policy mobile_policy
tunnel-group mobilegroup ipsec-attributes
pre-shared-key key
class-map global-class
match default-inspection-traffic
class-map inspection
class-map inspection_default
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:8483359024d4bec86c077bb9dbbcd324
: end
  • VPN
157
