Problems using IPSEC Dinamic IPs and DDNS
I am trying to set up VPN GW-GW between C857 and C877. One of the sites has fixed IP, but the other one has dinamic IP assigned by ISP. If I use IPs when setting up ipsec tunnel with preshared keys, I find no problems, but if I use hostname for one of the sites, taking advantage of Dynamic DNS, vpn cant be established, with an error of key missmatch in the side where I use hostname.
I configure hostname in:
crypto isakmp key "key" hostname "hostnme"
Cryptomap: set peer "hostname"
Do I have to use for this situation with dynamic IPs certificates?
Can anyone help?
Thanks in advance
1 REPLY
Re: Problems using IPSEC Dinamic IPs and DDNS
You have to use "address" for this. IF you are trying to do it by DDNS, you have to use certificates.
Configure a CA server and you should be able to get this working with the Certificates.
Rate this post, if it helps.
Cheers
Gilbert
257
