ravpn problem
I have created a ravpn on tha ASA 8.0(4)(resently upgraded).
The clients can connect fine but they cannot ping the inside network of the asa.
I have included the the vpn pool on the no nat access-list.
What i observed was that when i ping from the asa the raclients, it is successful!!!!
After I do so then everything seems to work fine!! Isn't it strange?
1 ACCEPTED SOLUTION
Re: ravpn problem
Michalis, glad it worked, could you PLS rate post as resolved.
B.Regards
Re: ravpn problem
Michalis,
make sure you have in asa nat-t enable as this is one of the most common symptoms from what you are describing.
asa(config)#crypto isakmp nat-traversal 20
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml#Solution1
if you do already have this statement PLS post sanitized ASA config .
PLS rate any helpful posts
Re: ravpn problem
Great it was that command!!!!!!
Thanks a lot man!!!
Problem solved!!!
Re: ravpn problem
B.Regards
122
