Remote-access help into a 5505
Hi all. Needing some help with a remote-access into a 5505. I can vpn in just fine, I just cant seem to pass any traffic. When I do a "sho cryp ipsec sa", I see traffic being decrypted, but I do not see any traffic being encrypted back to me. I attached my config, could I get some help from you guys to see where I have gone wrong? I appreciate as always.
1 ACCEPTED SOLUTION
Silver
Re: Remote-access help into a 5505
The reason why it is happening is because the ASA also has one L2L tunnel and you are using same NAT 0 access-list for L2L tunnel as Crypto ACL also.
nat (inside) 0 access-list tocw
crypto map outside_map 10 match address tocw
so the traffic you are sending from vpn client is actually returning back to L2L tunnel .
Do the following:
Create separate access-list for L2L tunnel specifying traffic only specific to L2L tunnel.
you have to check remote side but i think your crypto acl for l2l tunnel would be
access-list VPNACL extended permit ip 192.168.201.0 255.255.255.0 192.168.73.0 255.255.255.0
no crypto map outside_map 10 match address tocw
crypto map outside_map 10 match address VPNACL
Your L2L tunnel will come down when you will make changes so make necessary arrangements.
Check and post results
Saju
Pls rate helpful posts
Silver
Do the following:
Saju
I cant believe I didnt think of that. Thanks Saju. I appreciate it.
91
