You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Remote Connection is not working
Below is the VPN setup using wizard PIX515e.
tested on simulation it works but not on real environment.Any wrong config?
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxx encrypted
passwd xxxxxxencrypted
hostname ciscopix
domain-name cisco.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list abc_splitTunnelAcl permit ip host 192.168.253.0 any
access-list inside_outbound_nat0_acl permit ip host 192.168.253.0 192.168.253.24
8 255.255.255.248
access-list outside_cryptomap_dyn_20 permit ip any 192.168.253.248 255.255.255.2
48
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.0
ip address inside 192.168.253.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool abc 192.168.253.250-192.168.253.254
pdm location 192.168.253.0 255.255.255.255 inside
pdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-
http 192.168.253.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup abc address-pool abc
vpngroup abc split-tunnel abc_splitTunnelAcl
vpngroup abc idle-time 1800
vpngroup abc password ********
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:xxxxx
: end
  • VPN
Silver
Re: Remote Connection is not working
Your ip addressing is all messed up. Your internal ip address is 192.168.253.1/24, but you are trying to use crypto maps to connect to hosts on 192.168.253.248/28, which is on the subnet that the inside interface is connected to. If the pix thought it had any traffic for those hosts, it would send it out its inside interface, and not thru a crypto tunnel that it would never attempt to negotiate
I suggest you make these changes and this should work:
Change the ip pool , let the ip pool be different from the inside address :
ip local pool abc 10.1.2.1-10.1.2.254
Please remove this command , match-address is used only in the case of L2L tunnel.
no access-list outside_cryptomap_dyn_20 permit ip any 192.168.253.248 255.255.255.2 48
no crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
Please add this command:
isakmp identity address
Please refer to the following link for more information:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a008009442e.shtml
Let me know if you have any queries.
Deepali
208
