Remote gateway not responding using linksys vpn client
Please i need your assistance asap
Am using this
Linksys VPN router RV042, firmware version 1.3.12.19-tm
Linksys  VPN Client version 1.2.11
When i trying connecting via the VPN client on a window XP SP3 system it
goes through the process of connecting,provisioning, activating policy
and hang on verifying network. After a while a pop box comes up with ''
The remote gateway is not responding. Do you want to wait''
The RV042 shows that the client is log on  and online.but the VPN client
access say The remote gateway is not responding. Do you want to wait''
see below my vpn client log
2012/07/26 16:17:55 [STATUS]OS Version: Windows XP
2012/07/26 16:17:55 [STATUS]Windows Firewall is OFF
2012/07/26 16:17:55 [STATUS]One network interface detected with IP address 10.54.39.59
2012/07/26 16:17:55 [STATUS]Connecting...
2012/07/26 16:17:55 [STATUS]Connecting to remote gateway with IP address: 41.78.96.45
2012/07/26 16:18:10 [STATUS]Remote gateway was reached by https ...
2012/07/26 16:18:10 [STATUS]Provisioning...
2012/07/26 16:18:23 [STATUS]Tunnel is connected successfully.
2012/07/26 16:18:23 [STATUS]Verifying Network...
2012/07/26 16:18:27 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:18:30 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:18:31 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:18:33 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:18:36 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:18:59 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/07/26 16:19:10 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:19:13 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:19:18 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:19:21 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:19:27 [WARNING]Failed to ping the remote VPN Router!
2012/07/26 16:19:55 [WARNING]Ping was blocked, which can be caused by an unexpected disconnect.
2012/07/26 16:20:03 [STATUS]Disconnecting...
2012/07/26 16:20:17 [STATUS]Tunnel is disconnected successfully.
PLEASE I NEED HELP!!!!!! OR ANY OTHER OPTION TO ACCESS MY CENTRAL VPN GATEWAY
Celestine
Specstech Africa
573
