Community Member
Remote VPN configuration on ASA5510 does not work for iPhone but working for PC
I have remote access vpn configured on ASA5510 (firmware version 7.22), the configuation works for PC using Cisco VPN client software without any problem.
But when I configured iPhone IPSEC VPN. The VPN connection cannot be setup after I entered username and password.
I monitored the log. It gave me the following. I am not sure what caused this problem. If you know something, please help!
3Jan 30 201217:18:11713119Group = TWVPN, Username = achen, IP = 111.241.211.96, PHASE 1 COMPLETED
3Jan 30 201217:18:11713902Group = TWVPN, Username = achen, IP = 111.241.211.96, QM FSM error (P2 struct &0x4b3ff20, mess id 0xd3072042)!
3Jan 30 201217:18:11713902Group = TWVPN, Username = achen, IP = 111.241.211.96, Removing peer from correlator table failed, no match!
Adam
1 REPLY
Hall of Fame Super Silver
Re: Remote VPN configuration on ASA5510 does not work for iPhone
The "...no match!" error above usually indicates that there is no matching IPSec Phase 2 method between the ASA and the peer (iPhone in this case).
Please review the required settings here and verify that you have iPhone-compatible settings configured on your ASA.
900
