remote vpn doesn't work on Cisco 7206
Hi there,
I am doing a test to configure remote VPN access to Cisco 7206 (simulated by dynamips). The relevant configuration is as follows:
hostname Concentrator
aaa new-model
aaa authentication login xauth local
username ciscouser password 0 cisco1234
ip subnet-zero
crypto isakmp policy 10
hash md5
group 2
authentication pre-share
crypto isakmp client configuration group test
key cisco123
pool mypool
crypto map REMOTEACCESS client authentication list xauth
crypto ipsec transform-set RTP-TRANSFORM esp-des esp-md5-hmac
crypto dynamic-map vpn 1
set transform-set RTP-TRANSFORM
crypto map REMOTEACCESS client configuration address initiate
crypto map REMOTEACCESS client configuration address respond
crypto map REMOTEACCESS 1 ipsec-isakmp dynamic vpn
interface Ethernet0/0
ip address 150.1.1.1 255.255.255.0
interface Ethernet0/1
ip address 11.10.1.1 255.255.255.0
no ip directed-broadcast
ip local pool mypool 10.1.10.0 10.1.10.254
ip nat translation timeout never
ip nat translation tcp-timeout never
ip nat translation udp-timeout never
ip nat translation finrst-timeout never
ip nat translation syn-timeout never
ip nat translation dns-timeout never
ip nat translation icmp-timeout never
ip classless
ip route 0.0.0.0 0.0.0.0 10.103.1.1
no ip http server
end
However, when I try to connect the router via Cisco client 4.6, the following error appears:
05:04:52: ISAKMP (0:1): Checking ISAKMP transform 13 against priority 10 policy
05:04:52: ISAKMP: encryption DES-CBC
05:04:52: ISAKMP: hash MD5
05:04:52: ISAKMP: default group 2
05:04:52: ISAKMP: auth XAUTHInitPreShared
05:04:52: ISAKMP: life type in seconds
05:04:52: ISAKMP: life duration (VPI) of 0x0 0x20 0xC4 0x9B
05:04:52: ISAKMP (0:1): Xauth authentication by pre-shared key offered but does not match policy!
05:04:52: ISAKMP (0:1): atts are not acceptable. Next payload is 3
05:04:52: ISAKMP (0:1): Checking ISAKMP transform 14 against priority 10 policy
05:04:52: ISAKMP: auth pre-share
05:04:52: ISAKMP (0:1): Preshared authentication offered but does not match policy!
05:04:52: ISAKMP (0:1): atts are not acceptable. Next payload is 0
Does anybody have any idea? Thanks in advance.
1 ACCEPTED SOLUTION
Re: remote vpn doesn't work on Cisco 7206
Wang,
Thanks for the update! Glad its working.
The below commands are for group policy lookup.
aaa authorization network groupauthor local
crypto map REMOTEACCESS isakmp authorization list groupauthor
Since, you have configured the Group Policy (name,presharedkey,etc) locally on the router, you need to tell the router where to look for isakmp policies when VPN Cient tries to connect.
I hope it helps.
Arul
** Please rate all helpful posts **
Jun,
Add the below lines to the configuration and try bringing up the tunnel.
Let me know how it goes.
Arul
Arul,
It works. However, I am not clear why the authorization is a must. In fact, my network is very simple: the computer running VPN client directly connect to the Router.
C u kindly tell me what the command is for?
Thanks and Regards,
Wang Jun
Wang,
I hope it helps.
Arul
361
