Community Member
Remote VPN problem!
There is a problem between vpn client 4.01 and PIX515E,The PIX version is 7.0
The pix configuration file ,what is the problem ?
pix# sh run
: Saved
PIX Version 7.0(2)
interface Ethernet0
nameif outside
security-level 0
ip address
interface Ethernet1
nameif inside
security-level 100
ip address
boot system flash:/pix702.bin
ftp mode passive
access-list 101 extended permit tcp any host eq www
access-list 101 extended permit tcp any host eq ftp
access-list 158 extended permit ip
access-list split standard permit
pager lines 24
logging enable
logging timestamp
logging standby
mtu outside 1500
mtu inside 1500
ip local pool testpool
no vpn-addr-assign dhcp
monitor-interface outside
monitor-interface inside
asdm image flash:/asdm-504.bin
asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list 158
nat (inside) 1
static (inside,outside) tcp www www netmask
static (inside,outside) tcp ftp ftp netmask
access-group 101 in interface outside
route outside 1
route inside 1
route inside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
group-policy hygp internal
group-policy hygp attributes
vpn-idle-timeout 30
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split
username hypix password qZYBtyuPGlJNbeT4 encrypted
http server enable
http inside
http inside
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps snmp
sysopt noproxyarp inside
crypto ipsec transform-set aaades esp-des esp-md5-hmac
crypto dynamic-map dynomap 10 set transform-set aaades
crypto map vpnpeer 20 ipsec-isakmp dynamic dynomap
crypto map vpnpeer interface outside
isakmp enable outside
isakmp policy 8 authentication pre-share
isakmp policy 8 encryption des
isakmp policy 8 hash md5
isakmp policy 8 group 2
isakmp policy 8 lifetime 86400
telnet inside
telnet inside
telnet timeout 5
ssh scopy enable
ssh outside
ssh outside
ssh inside
ssh timeout 10
ssh version 1
console timeout 5
tunnel-group hy type ipsec-ra
tunnel-group hy general-attributes
address-pool testpool
default-group-policy hygp
tunnel-group hy ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map globle_policy
class inspection_default
policy-map global_policy
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect http
inspect netbios
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
policy-map global_plolicy
Re: Remote VPN problem!
just a quick comment.
the vpn client pool should not be overlapped with the pix inside net.
Community Member
