Site to site with dynamic ip problems
Hi, I have two Cisco 881 routers, one with a fixed ip (hub called RTV) and one with a dynamic ip via dhcp (spoke called RTVWeee).
I have configured them according to this guide http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00801dddbb.shtml but am unable to get any connectivity between them.
Any help would be greatly appreciated! What am I missing and what am I doing wrong?
BR,
Chris
Hub reports:
RTV#show crypto ipsec profile
RTV#
RTV#show crypto isakmp sa detail
Codes: C - IKE configuration mode, D - Dead Peer Detection
       K - Keepalives, N - NAT-traversal
       T - cTCP encapsulation, X - IKE Extended Authentication
       psk - Preshared key, rsig - RSA signature
       renc - RSA encryption
IPv4 Crypto ISAKMP SA
C-id  Local           Remote          I-VRF    Status Encr Hash Auth DH Lifetime Cap.
IPv6 Crypto ISAKMP SA
RTV#show ip interface
FastEthernet0 is down, line protocol is down
  Internet protocol processing disabled
FastEthernet1 is down, line protocol is down
FastEthernet2 is down, line protocol is down
FastEthernet3 is up, line protocol is up
FastEthernet4 is up, line protocol is up
  Internet address is 77.77.77.77/29
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Outgoing access list is not set
  Inbound  access list is not set
  Proxy ARP is disabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are never sent
  ICMP unreachables are never sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
  Input features: Stateful Inspection, Ingress-NetFlow, Virtual Fragment Reassembly, IPSec input classification, Virtual Fragment Reassembly After IPSec Decryption, NAT Outside, MCI Check
  Output features: Post-routing NAT Outside, Stateful Inspection, IPSec output classification, Post-Ingress-NetFlow, IPSec: to crypto engine, Post-encryption output features
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
NVI0 is up, line protocol is up
  Interface is unnumbered. Using address of FastEthernet4 (77.77.77.77)
  MTU is 1514 bytes
  Proxy ARP is enabled
  ICMP redirects are always sent
  ICMP unreachables are always sent
  IP fast switching is disabled
  IP CEF switching is disabled
  IP Null turbo vector
  Network address translation is disabled
  Input features: MCI Check
  Output features: Post-routing NAT NVI Output, Post-Ingress-NetFlow
Vlan1 is up, line protocol is up
  Internet address is 172.16.0.1/20
  MTU is 1500 bytes
  Network address translation is enabled, interface in domain inside
  Input features: Stateful Inspection, Ingress-NetFlow, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check, TCP Adjust MSS
  Output features: NAT Inside, Stateful Inspection, TCP Adjust MSS, Post-Ingress-NetFlow
RTV#
Hub configuration:
RTV#show running-config
Building configuration...
Current configuration : 3392 bytes
! Last configuration change at 17:23:29 PCTime Wed Feb 29 2012 by ChrisRTV
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname RTV
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 $1$..8A$xz5K0Y4HxiMGfVLGiHaJc/
aaa new-model
aaa authentication login clientauth local
aaa authorization network groupauthor local
aaa session-id common
memory-size iomem 10
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-4044243786
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4044243786
revocation-check none
rsakeypair TP-self-signed-4044243786
no ip source-route
ip dhcp excluded-address 172.16.0.1 172.16.1.99
ip dhcp excluded-address 172.16.1.111 172.16.15.254
ip dhcp pool ccp-pool1
   network 172.16.0.0 255.255.240.0
   default-router 172.16.1.1
ip cef
no ip bootp server
no ip domain lookup
ip domain name chris.no
ip name-server 195.159.0.100
ip name-server 195.159.0.200
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn FCZ16039575
username ChrisRTV privilege 15 secret 5 $1$GHYL$naUrqaHlFGYdccxqajfbr/
ip tcp synwait-time 10
crypto keyring spokes
  pre-shared-key address 0.0.0.0 0.0.0.0 key RTV123
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp profile L2L
   description LAN-to-LAN for spoke router(s) connection
   keyring spokes
   match identity address 0.0.0.0
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
set isakmp-profile L2L
crypto map mymap 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $ES_WAN$
ip address 77.77.77.77 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
crypto map mymap
interface Vlan1
description INSIDE
ip address 172.16.0.1 255.255.240.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
ip tcp adjust-mss 1452
ip default-gateway 172.16.0.1
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 23 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip access-list extended ENCRYPT
permit ip host 172.16.1.1 host 172.16.0.1
logging trap debugging
access-list 23 permit 10.10.10.0 0.0.0.7
access-list 23 permit 172.16.0.0 0.0.255.255
no cdp run
control-plane
banner exec ^CC
Get out^C
banner login ^CC
Get out
^C
line con 0
no modem enable
transport output telnet
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
transport input ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Spoke reports:
RTVWeee#show crypto isakmp sa detail
RTVWeee#
RTVWeee#show crypto ipsec sa
interface: FastEthernet4
    Crypto map tag: mymap, local addr 192.168.1.194
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (172.16.1.0/255.255.15.0/0/0)
   remote ident (addr/mask/prot/port): (172.16.0.0/255.255.15.0/0/0)
   current_peer 77.77.77.77 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 192.168.1.194, remote crypto endpt.: 77.77.77.77
     path mtu 1500, ip mtu 1500, ip mtu idb FastEthernet4
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
RTVWeee#
And spoke configuration:
RTVWeee#show running-config
Current configuration : 4469 bytes
! Last configuration change at 17:58:06 PCTime Wed Feb 29 2012 by ChrisRTV
version 15.0
no service pad
hostname RTVWeee
boot-start-marker
boot-end-marker
no aaa new-model
crypto pki certificate chain TP-self-signed-4044243786
certificate self-signed 01
  3082024C 308201B5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34303434 32343337 3836301E 170D3132 30323238 31363131
  34345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30343432
  34333738 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100C46B E491C359 858C5AD0 13B739CE 7D4ADA1D 1E571FC9 E85F0FA9 95488F97
  CDA6FC02 83485A89 B3CBCA3F 39FEEAD0 BAAD9595 7CB02737 3D7CDE56 8A758593
  EF8401DB A6DFDFC8 17535C67 CB22F529 A5269216 6B93D442 E34AA859 4CCB215A
  6951C4B0 14B28A6A 36B59AEB 3F8E1CC9 CEE923EE 48FFF005 B89DC1A6 7C62BBAA
  9B0B0203 010001A3 74307230 0F060355 1D130101 FF040530 030101FF 301F0603
  551D1104 18301682 14525456 57656565 2E70726F 74656374 61732E6E 6F301F06
  03551D23 04183016 8014315A E18BC683 9DFF6A6D 61DDEB8B 9D01A4C4 9487301D
  0603551D 0E041604 14315AE1 8BC6839D FF6A6D61 DDEB8B9D 01A4C494 87300D06
  092A8648 86F70D01 01040500 03818100 97460892 949A6F9A 29278C7C A3D7A856
  382C02B6 90BD14AF 5F686327 04C348C9 018C5B79 EF0B0A10 FB6C38EA 41727EC9
  927B3B10 766F5656 E91938EC FC839BBB 335B33D0 86DCB0AE 139F6429 993C9E70
  E842FDD5 B1D3CD3A 55990A46 B42AF93C ABED8C18 8C3DE882 9A5E40FF B1193B7B
  5F5F0DAF BF297304 E87CFD1E 27E9AD05
        quit
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
no ipv6 cef
license udi pid CISCO881-SEC-K9 sn FCZ1603957K
username ChrisRTV privilege 15 secret 5 $1$djIv$okpuA.tuNiWgZ/jpqEaFB.
encr 3des
group 2
crypto isakmp key RTV2012 address 77.77.77.77
set peer 77.77.77.77
match address 100
883
