small help with ASA site-site vpn with Natting potected network
hi all ,
i have asa with ios 9.x and running sit-site vpn
the two protected networks on both sides are shown below :
192.168.10.0/24
192.168.1.0/24
the current topology when the vpn works is :
192.168.10.0/24------asa1---------internet-----asa2------192.168.12.0/24
with the topology above , the vpn works !
now , i made some changes in network and it seems that network 192.168.10.0/24 is not available now and replaced with 10.0.0.0/24
10.0.0.0/24-------asa1-----internet----asa2---192.168.12.0/24
also , i dont have an access to asa2 , so the only way i can is modify asa1
the question is :
wt do i need to modify asa1 so that it get the vpn working ???
i added a nat rule on asa1 that nat the src ips of 10.0.0.0/24-----> to ----->192.168.10.0/24 when it go to 192.168.12.0/24
but still vpn is down ?
im asking now , do i need to do any other thing to let it works ?
regards
with
1 ACCEPTED SOLUTION
Hi Ahmed, By default isakmp
Hi Ahmed,
By default isakmp nat-traversal is enabled on cisco firewalls..... I have tested it in my lab and it worked like charm.... might be u r missiing something very basic....
Karthik
Silver
Have you modified a cryptoto
Have you modified a cryptoto ACL as well ?
Can you please provide a show run of the ASA.
Also I would recommend you to run a packet tracer with debug crypto IPSEC 125 and debug crypto ISAKMP 128 in order to troubleshoot .
-RANDY -
hi , thanks for answers ,but
hi ,
but im just asking , do i need more things more than doing NAT ???
does in this case NAT-T must be enabled at both sides of vpn ?
i  will soon , post the config here ,
regards
Hi Ahmed,
Karthik
Hi ,  thank you all ,the
Hi ,
thank you all ,
the problem was beyond the ASA it was routing issue out of the ASA.
i just want to thank you for replying and your time.
==> yes , as i mentioned no need to modify anything if i need nating , because the nat is done before the crypto look up.
now it works like a charm.
regards
Hi,can you enable debug on
can you enable debug on asa1 and check where it is not coming up...
debug crypto ipsec 255 or debug crypto ipsec 7
Hope you shouldn't have the problem with phase 1.....
Have you checked on the NAT traversal  enabled on the firewalls?
Karthik
34
