Specific VPN requirements, need help selecting correct technology
I need assistance selecting the correct vpn technology to meet my requirements.
I have a 2801 router that I will be using to terminate the vpn sessions. I will be using 871 series routers for the remote clients. The requirements that make it difficult for me to determine how to configure are:
The 871 routers WAN ip address will be dynamic, so I cant use standard IPSEC lan to lan configuration. The solution needs to allow the connection from any address.
The remote sites will also need to pass traffic between remote sites. I need to allow this because this VPN is going to be used for IP Phones and I want clients at remote sites to be able to call each other.
Some of the solutions I have seen require the remote user to enter a username and password from the CLI on their 871 to bring up the tunnel. If at all possible I dont want this to be a dependency.
I am familiar with cisco routers and can usually make a config work if provided an example, but I dont know enough about the various VPN options to choose the correct solution. Any help is greatly appreciated.
1 ACCEPTED SOLUTION
Re: Specific VPN requirements, need help selecting correct techn
If you need spoke-to-spoke vpn connection as well, you can try DMVPN.
http://www.cisco.com/en/US/products/ps6658/prod_presentation_list.html
Hi kwu2, thanks for the reply.
The remote sites dont need to talk directly to each other, their traffic can flow thru the hub router if that makes for a simplier solution. There is only going to be about 6 sites and the only traffic will be RTP and Skinny from a single phone per location.
Ok, in that case, you can use dynamic crypto map on Hub router, like the router config in the following link.
http://www.cisco.com/en/US/partner/tech/tk583/tk372/technologies_configuration_example09186a008051a69a.shtml
Any you need pay attention to those routing and ACL setting on spoke and hub routers, you can refer to the following example.
http://www.cisco.com/en/US/partner/tech/tk583/tk372/technologies_configuration_example09186a0080093dc8.shtml
Hi kwu2:
I went with your orignal advice and setup spoke-to-spoke dmvpn with minimal trouble. I used this document as an example.
http://www.cisco.com/en/US/partner/tech/tk583/tk372/technologies_configuration_example09186a008014bcd7.shtml
Thanks Again
129
