Split tunnels using DMVPN and VLAN's
Looking to deploy a solution using an 877 router. The wireless and Fa0-2 need to be part of the DMVPN back to a Cisco 3845. I need to break the fa3 out directly to the internet with a local IP for Lan connectivity. Can I just create a separate dialer and use this to connect the fa3 out to the raw internet?
235
