03-18-2004 05:53 AM
Hello forum,
I have experience an issue with the new feature on Concentrator 3005. I have configured client authentication using certificate, however when the certificate is located on a smartcard the SSL connection failed. There is no issue when the certificate is located on the machine.
The error that i am getting in the log file is:
Certificate is valid: session = 12
> 589 01/08/2004 13:39:01.390 SEV=9 CERT/0 RPT=13 No CRLs checks necessary.
> 590 01/08/2004 13:39:01.390 SEV=8 CERT/50 RPT=13
> CERT_Callback(1cb8b80,0,
0)
> 591 01/08/2004 13:39:01.580 SEV=3 CAPI/26 RPT=7 CAPI - RSA PKCS1
> payload to be decrypted is not in PKCS1 format, bad block type = [0xad][0xf8]
Thanks.
Yossi Mor
03-24-2004 07:06 AM
You are probably running into CSCea12148. To fix this problem, you will have to delete the SSL certificate from administration/certificate page and generate a new SSL certificate.
03-27-2004 11:48 PM
I appreciate your replay to my question, however the workaround that you have suggested did not resolve the problem.
When the certificate is stored on the machine there is no problem to open SSL connection. However This is not the case when the certificate is stored on the smartcard.
Regards.
Yossi Mor
