SSL tunnel for LAN to LAN
I am designing a temporary solution for VPN as a backup. This is using a ASA, and SSL VPN.
The problem I have is, I have to terminate SSL VPN on a Linux box/firewall on other end. I need LAN to LAN connection with SSL VPN from ASA to Linux systems.
So my questions are -
As I can't use any client on other side for SSL VPN, can I use clientless VPN configuration for Linux to allow entire LAN network on Linux side to pass on VPN?
Is there any other better way?
One more option I have, is to use openvpn software on Linux end this supports LAN to LAN SSL VPN.
1 REPLY
Silver
Re: SSL tunnel for LAN to LAN
You can use Cisco Secure Desktop connection. It minimizes the risk involved in SSL VPN by cleaning cookies and cache of browser. Refer http://cisco.com/en/US/docs/security/csd/csd311/csd_for_asa/configuration/guide/CSDJntro.html#wpxref53464.
272
