Sup engine
Hi Experts,
I need some more information about supervisor eng.
1) Can switch boot & work without sup eng. , if yes what is the advantages to use sup eng.
2) In which slot we can put sup eng. & how it works
3) How to configure sup eng.
Thanks In advance
Regard's
Surya
1 ACCEPTED SOLUTION
Sup engine
No.
What kind of switch you are talking about. Refer to the switch manual.
Initial- just like the way you configure any other Cisco device (console)
hth
MS
1 REPLY
Sup engine
No.
hth
MS
351
