Telnet_to_port_25_is_not_opening_from_outside
product - ASA firewall
Problem -
D:\Documents and Settings\Administrator>telnet 122.166.x.x 25
Connecting To 122.166.x.x...Could not open connection to the host, on port 25:
Connect failed
Hi Cisco Team, Im unable to telnet to nat ip of the exchange server with port 25.
configuration
access-list 105 extended permit tcp any host exch_ip eq smtp
access-group 105 in interface outside
what are the other ports to be opened for accessing smtp from outside apart from smtp ?? - Now its not working !!
regards
Rajesh P
1 REPLY
Re: Telnet_to_port_25_is_not_opening_from_outside
could you show the configuration?
you need static NAT or PAT
153
