Community Member
Tunnel Problem
i'm trying to create a GRE tunnel with IPSEC in ospf routing environment between two routers.
I have made a testing configuration.Kindly tell anyone my configuration is correct or not.
If not correct kindly suggest me actual configuration.
1 REPLY
Community Member
Re: Tunnel Problem
I think that your configuration is right but it is better to check the sample configuration for GRE Tunnel over IPSec with OSPF present in the url provided below and make the necessary changes.
configuring a GRE Tunnel over IPSec with OSPF:
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800a43f6.shtml
259
