VPN Help with connecting to remote lan
dspeciale
I am trying to setup a vpn. I am using cisco client version 4.6
I am having trouble getting to my remote lan.
I can connect and receive and ip from the vpnpool from the firewall, but I cannot ping or access any resources on the network.
I keep going over my config and I can't figure out what I am missing.
Dee
Links to my config:
Switch
http://docs.google.com/Doc?id=dmtt4nj_32fhpnvwd3
Firewall
http://docs.google.com/Doc?id=dmtt4nj_33c3ng6dhq
acomiskey
Level 10
Level 10
This route statement isn't necessarily correct as your vpn pool is 192.168.3.x.
route inside 192.168.103.0 255.255.255.0 10.250.1.2 1
If you actually have a 192.168.3.0/24 network inside, then use something entirely different for you vpn pool.
