Community Member
VPN issue with Cisco clients behind asa to remote network
I can connect and authenticate to the remote network, but i cannot access remote resources. I have ipsec listed under global inspections, i think my acls are ok...Any help greatly appreciated 'cause I'm stuck... Here's my config:
Thank you,
Mike
Green
Re: VPN issue with Cisco clients behind asa to remote network
Which ASA is this? The one the vpn clients are behind or the one they are terminating vpn to? I assume due to lack of configuration it is the one the clients are behind. Check for nat-traversal on the remote end device.
Community Member
You are right, it's the ASA the clients are behind. It's a Cisco 5510, sorry i left that out. I also attached my config to my previous post, but here it is again with some exclusions do to post limits:
ASA Version 7.2(3)
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group service UDPforVPN udp
port-object range 4500 4500
port-object eq echo
port-object eq isakmp
access-list vpnusers_splitTunnelAcl standard permit any
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended permit ip any any
access-list inside_access_in remark udp for vpn
access-list inside_access_in extended permit udp any any
access-list outside_access_in remark incoming from outside everyone to ***.com on the inside 192.168.10.6
access-list outside_access_in extended permit tcp any object-group ***.com host 192.168.10.6 object-group ***.com inactive
access-list outside_access_in remark incoming from outside everyone to ***.com on the inside 192.x.x.20
access-list outside_access_in extended permit tcp any object-group ****.com host 192.x.x.20 object-group ****.com inactive
access-list outside_access_in extended permit tcp any host 192.x.x.x inactive
access-list outside_access_in remark incoming udp for vpn
access-list outside_access_in extended permit udp any object-group UDPforVPN any object-group UDPforVPN inactive
access-list vpnusergroup_splitTunnelAcl standard permit any
access-list dmz_access_in remark access rule for ***.com TCP FTP and FTP-data outside-->dmz
access-list dmz_access_in extended permit tcp any object-group ***.com host 192.x.x.x object-group ***.com inactive
access-list outside extended permit tcp any any eq pptp
access-list outside extended permit gre any any
access-list outside extended permit udp any any
access-list inside extended permit tcp any any eq pptp
access-list inside extended permit gre any any
access-list inside extended permit udp any any
access-list inside_access_out extended permit ip any any
nat-control
global (outside) 101 interface
nat (inside) 101 0.0.0.0 0.0.0.0
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 0.0.0.0 0.0.0.0 99.165.4.134 1
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
http server enable
http 192.x.x.x 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec fragmentation after-encryption management
crypto ipsec fragmentation after-encryption dmz
crypto isakmp enable inside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 3600
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ctiqbe
inspect dcerpc
inspect http
inspect icmp
inspect icmp error
inspect ils
inspect ipsec-pass-thru
inspect mgcp
inspect pptp
inspect snmp
inspect waas
service-policy global_policy global
Silver
I think you are missing nat bypass statement ,
Nat 0 access-list
136
