VPN Routing Problem
dfvelasco
We need to connect from an external computer connected by cisco-vpn-client to one internal server that is behind an ASA 5505 config with Easy VPN. The VPN connection with the client to our 5520 firewall is fine, but when I try to connect to the server on the LAN, FW log says:
Routing failed to locate next hop for TCP from Internet:172.17.1.215/1108 to Lan_Interna:172.33.0.50/3389
Attached image.
Can you help me?
David
There is a number of incorrect NAT statements which should be removed:
nat (Lan_Interna,DMZ) source static INTRANET_LISBOA INTRANET_LISBOA no-proxy-arp
nat (Lan_Interna,any) source static INTRANET_LISBOA INTRANET_LISBOA destination static DMZ DMZ no-proxy-arp
nat (Lan_Interna,any) source static INTRANET_LISBOA INTRANET_LISBOA destination static VPN_REMOTE_ACCESS VPN_REMOTE_ACCESS no-proxy-arp
On the VPN Client route section, do you see the 2 routes, or there is just 1 route of 0.0.0.0?
Also, have you reconnected the ASA5505? if you have, how come there is no IPSec SA? there should be an IPSec SA for that peer, otherwise, it won't work. Can you access the main site from the ASA5505?
22 Replies 22
Jennifer Halim
Do you have a route for the 172.33.0.50 ip address?
can you share your config pls.
Hello Jennifer,
Thank you for your answer!! No, I don't have static route for 172.33.0.0/16 LAN
Is posibble that we loss the connection with this LAN if I config static route?? Remeber that this office is connected throught Easy VPN Client
David
Ahh, is it Easy VPN in NEM (Network Extension Mode)?
Should 172.33.0.0/16 be routed towards the Internet instead? is 172.33.0.0 the easy VPN local subnet?
It would be easier if you share your current config.
Not quite sure if vpn client to easy vpn client connection will work. But pls share your config to see.
Correct! It's Easy VPN in NEM.
172.33.0.0 it's the local subnet. My ASA 5505 config:
ASA Version 8.2(5)
hostname ciscoasa
domain-name xxxx
enable password xxxxx encrypted
passwd xxxx encrypted
names
name 192.168.0.0 DMZ
name 172.20.0.94 EXBCN02
name 172.33.0.50 DCLIS01
name 172.20.0.79 DCBCN02
name 172.20.0.0 INTRANET_BCN
interface Ethernet0/0
 switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
 nameif inside
 security-level 100
 ip address 172.33.0.254 255.255.0.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 192.168.1.2 255.255.255.0
time-range INFORMATICA
 absolute end 09:41 28 June 2012
boot system disk0:/asa825-k8.bin
ftp mode passive
dns server-group DefaultDNS
 domain-name red.xxxx.es
access-list outside_nat0_outbound extended permit ip any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-645.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 172.33.0.0 255.255.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto ca trustpoint _SmartCallHome_ServerCA
 crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
 certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
    308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
    68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
    3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
    63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
    0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
    a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
    9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
    7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
    15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
    63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
    18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
    4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
    81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
    db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
    7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
    ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
    45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
    2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
    1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
    03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
    69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
    02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
    6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
    c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
    69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
    1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
    551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
    1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
    2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
    4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
    b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
    6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
    481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
    b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
    5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
    6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
    6c2527b9 deb78458 c61f381e a4c4cb66
  quit
no vpn-addr-assign aaa
no vpn-addr-assign dhcp
telnet DCLIS01 255.255.255.255 inside
telnet 172.33.0.52 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcp-client client-id interface outside
vpnclient server 195.77.x.x
vpnclient mode network-extension-mode
vpnclient nem-st-autoconnect
vpnclient vpngroup REMOTE_LISBOA password *****
vpnclient username LISBOA password *****
vpnclient management clear
vpnclient enable
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
 vpn-tunnel-protocol IPSec l2tp-ipsec
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
prompt hostname context
call-home reporting anonymous
call-home
 profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:ad344e66d6f49cd7f75943963656d809
: end
asdm location DMZ 255.255.255.0 inside
asdm location EXBCN02 255.255.255.255 inside
asdm location DCLIS01 255.255.255.255 inside
asdm location DCBCN02 255.255.255.255 inside
asdm location INTRANET_BCN 255.255.0.0 inside
I need to connect from outside to 172.33.0.0/16
Thanks!
Sorry, I need to connect from external computer with cisco-vpn-client to our main office FW (195.77.x.x) and then acces to 172.33.0.0/16
The connection from computer to FW it's OK, but then the problem with 172.33.0.0/16
Thanks again. Tell me if you need the config from ASA 5520 (195.77.x.x)
need the 5520 config as there is where the vpn client config and vpn server config is
Hello Jennifer,
I configure a static route to 172.33.0.0/16 on ASA 5520 and loose the connection to servers in Easy VPN office. Route deleted.
Attached 5520 config.
Easy VPN Office Profile: REMOTE_LISBOA (it's connected and working)
Cisco-vpn-client (remote computer) vpn profile: REMOTE_ITLISBOA
David
Split tunnel needs to be standard ACL instead of extended ACL.
Also, REMOTE_LISBOA_splitTunnelAcl ACL is incorrect, you have destination network at the IP POOL subnet, it should have been 172.33.0.0 subnet. In any case, you can just configure standard ACL instead of extended ACL.
The standard ACL should be as follows:
access-list REMOTE_LISBOA_splitTunnelAcl standard permit object INTRANET_MAD
access-list REMOTE_LISBOA_splitTunnelAcl standard permit object INTRANET_BCN
access-list REMOTE_LISBOA_splitTunnelAcl standard permit object VLAN_MAD
access-list REMOTE_LISBOA_splitTunnelAcl standard permit object DMZ
access-list REMOTE_LISBOA_splitTunnelAcl standard permit object INTRANET_DIAGONAL
access-list REMOTE_LISBOA_splitTunnelAcl standard permit object VPN_REMOTE_ACCESS
BTW, you have a very long config
Ok, I will change the config and I tell you something tomorrow.
I suppose that I must disconnect Easy vpn client and connect again to apply the changes. Right??
I know, It's difficult to manage the config
Thanks again.
Yes, correct, you have to disconnect after you make the changes and reconnect again.
Hello Jennifer,
Bad news, same problem. Do I need to make any change on client profile (REMOTE_ITLISBOA)??
I made the standard ACL for REMOTE_LISBOA_splitTunnelAcl, disconnect the ASA 5505 and recconect again.
David
Also change the ACL to standard for the REMOTE_ITLISBOA:
access-list REMOTE_ITLISBOA_splitTunnelAcl standard permit object INTRANET_LISBOA
access-list REMOTE_ITLISBOA_splitTunnelAcl standard permit object INTRANET_BCN
Can you please advise where it is failing?
Please share the output of:
show cry ipsec sa peer
show cry ipsec sa peer <(REMOTE_ITLISBOA-ip-address>
Yes, pls change it to standard ACL as well.
Pls share the output of :
show cry ipsec sa peer ITLISBOA-ipaddress>
Where should I run the command? ASA5520 or ASA5505
