01-05-2012 03:24 PM
Is it possible to create a site-to-site ipsec vpn (lab environment) between two 5505's (ASA IOS 8.2(5) & asdm-645-206) with the same default gateway. I.E. a back to back site-to-site VPN tunnel or do I need to deploy a router and hang each 5505 off a different interface? We have plenty of public IP's but only one default gateway to our ISP (Internet). Any suggestions or recommendations are greatly appeciated!
d
Solved! Go to Solution.
01-06-2012 03:16 AM
Yes - you could even do it with an xover cable and a /30 ip on both outside interfaces.
01-06-2012 03:16 AM
02-20-2012 11:09 AM
Belated Thanks!. Works perfectly!
d
