00:00:04: %LINK-4-NOMAC: A randon +not reconized any interfaces(cisco 2620)
I have this router cisco 2620 with the folwing message at the power on and do not reconized any interface I instaled.
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
C2600 platform with 65536 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x4dd304
Self decompressing the image : ####################################################################################################################################################################################################################################################################################################################################################################################################################################################################################################### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-IS-M), Version 12.0(21a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sat 02-Feb-02 02:01 by nmasa
Image text-base: 0x80008088, data-base: 0x808FA740
cisco 2600 (MPC860) processor (revision 0x100) with 53248K/12288K bytes of memory.
Processor board ID JAB03110GUP (2632630101)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Press RETURN to get started!
00:00:04: %LINK-4-NOMAC: A random default MAC address of 0000.0c84.bf55 has
been chosen. Ensure that this address is unique, or specify MAC
addresses for commands (such as 'novell routing') that allow the
use of this address as a default.
00:00:14: %SYS-5-CONFIG_I: Configured from memory by console
00:00:14: %SYS-5-RESTART: System restarted --
Router>
Router>sh int
Router>sh ver
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Router uptime is 9 minutes
System restarted by power-on
System image file is "flash:c2600-is-mz.120-21a.bin"
Bridging software.
Hall of Fame Super Silver
Re: 00:00:04: %LINK-4-NOMAC: A randon +not reconized any interfa
Is this a router that you have had or is it one that you just acquired?
If you have had it a while did it work before? Have you upgraded the IOS? Do I understand that you have installed new interfaces? If so can you give us the specific part numbers of the interfaces? It sounds like the intefaces on the router may not be supported by the version of IOS that you are running.
Rick
Hello, rburts.
This is a router a just acquired and it supoused to be in good condition.
The interface I instaled was a wic-1T but I does not reconiced any one even the ethernet0.Also When I make a sh ver the interface do not apper.
Router>sh ver
Bridging software.
but I got this error:
What is the workaround for this situation?
I will apprecied any help about!
Best regardas!
JuanB
If it is a router that you have just acquired I would suggest that you remove (temporarily) the interface that you installed and see if the router will boot and recognize the other interfaces.
I do not know for sure what the problem is, but when the IOS does not recognize interfaces it is usually either a problem that the particular version of IOS on that platform does not support the particular interface, or it may be a hardware problem with the interface. It might be helpful to remove any interfaces that you can and re-insert them very carefully to be sure that they are well seated.
If the IOS version on the box the one that came with the router or did you load a different version of IOS?
Rick
Hi,rburts, me again, sorry I was out the town.
Answering yours questions:
I've been remoned all the interface and got the same situation,Also the ethernet0/0 that came with the router is not reconized when I make a sh ver or sh interfaces.
Is any produce to erase all the faslh and configured again the router?
Or if you have any other recomendation, pleased let me know?
Assuming that the router has done a normal boot you should be able to go into enable mode. From enable mode you can use the command erase flash to erase the contents of flash. Loading a new image will be a challenge if the router does not recognize any of its interfaces. You will probably need to boot the router into rommon and use something like xmodem to transfer the new image from a PC to the flash.
Rick
Rburts, I want to thanks you!
I erased the flash and load a new one using the xmodem produce.The router is working.
JuanB
Juan
I am glad that you solved the problem and got the router working. It looks like there was something incompatible between the router hardware and the particular IOS image that was on the router.
Rick
683
