02 DS3 Module in 3845
aamaral2006
I have one 3845 with DS3 connection and it works OK. I tried to insert the second DS3 module in it, and the router did not recognized the module. I will use the second module just to link test .
Any idea about the solution ?
TIA Amaral .
7 Replies 7
lamav
Level 8
Level 8
Did you try rebooting the router after the hardware installation?
aamaral2006
Yes, the router was turned off when I inserted the DS3 Module . TKS
If possible, turn off router, reseat module, turn on. If still trouble send output of "show diag".
Amaral
Depending on the type of card you may need this command before the router seems to recognize your card:
card type t3
Rick
Rick
aamaral2006
Hi, the router was turnned off, the type interface was configurated, but it doesnt work . Tks for the help
As mentioned above, when in trouble with router hardware, check "show diag".
vaisharm
Can you swap the working module with the new one and see if it works fine in the known good slot. Next, try the working module in the other slot. If its a HW fault this way we can narrow down if its a faulty slot or card.
In case the above excercise doesn't help, please do post the exact module part number and the IOS version in use.
HTH,
~Vaibhav
