09-17-2008 05:25 AM - edited 03-03-2019 11:35 PM
Someone was telling me that 1.1.1.1 address is routeable I thought it wasn't due to the face that it is a reserved address is that correct?
Solved! Go to Solution.
09-17-2008 10:06 AM
1.0.0.0 /8 is currently UNALLOCATED by IANA, that's why it's not routable.
http://www.iana.org/assignments/ipv4-address-space/
Hope that helps.
09-17-2008 10:06 AM
Hope that helps.
09-17-2008 11:10 AM
thank you for the help and pointing me to the right place but I must be blind as I don't see the 1.0.0.0/8 I will check again
but thanks for this!!!
09-17-2008 11:12 AM
It's a little goofy, but it's the second line,
001 /8
Which really means 1.0.0.0 255.0.0.0.
09-17-2008 11:21 AM
ok thanks for that
