1:1 NAT used for Cisco CallManager
I have a cisco call-manager located behind a DSL router. I am trying to allow inbound connections from the public internet to this call manager. I have setup a 1:1 NAT (have an additional /30 block routed towards my dialer interface) and can reach the web and other services on it just fine. The IP address of the CCM is 10.40.0.20.
The problem is I can't get phones to register remotely. These phones on the inside LAN will register and work just fine. I think NAT or something is breaking my inbound connections to the CCM.
Please see the config below and let me know if you can find the problem.
version 12.3
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname Cisco827
boot-start-marker
boot-end-marker
logging buffered 100000 debugging
enable secret xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
clock timezone CST -6
clock summer-time CST recurring
no aaa new-model
ip subnet-zero
ip dhcp excluded-address 10.40.0.1 10.40.0.50
ip dhcp pool DATA
network 10.40.0.0 255.255.255.0
dns-server xxxxxxxxxxxxxxxxxxxxx
default-router 10.40.0.1
class-map match-any VOIP
match ip precedence 3 5
policy-map BROADBAND
class VOIP
priority 256
class class-default
fair-queue
interface Ethernet0
ip address 216.243.xxx.xx5 255.255.255.252 secondary
ip address 10.40.0.1 255.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/32
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer1
description PPPoA Dialer to xxxxxxxxxxxxxxxxxxxxx
bandwidth 1500
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp pap sent-username xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
service-policy output BROADBAND
ip nat inside source list 101 interface Dialer1 overload
ip nat inside source static udp 10.40.0.5 3389 interface Dialer1 3389
ip nat inside source static tcp 10.40.0.10 5900 interface Dialer1 5900
ip nat inside source static udp 10.40.0.10 5900 interface Dialer1 5900
ip nat inside source static tcp 10.40.0.5 6889 interface Dialer1 6889
ip nat inside source static tcp 10.40.0.5 6888 interface Dialer1 6888
ip nat inside source static tcp 10.40.0.5 6887 interface Dialer1 6887
ip nat inside source static tcp 10.40.0.5 6886 interface Dialer1 6886
ip nat inside source static tcp 10.40.0.5 6885 interface Dialer1 6885
ip nat inside source static tcp 10.40.0.5 6884 interface Dialer1 6884
ip nat inside source static tcp 10.40.0.5 6883 interface Dialer1 6883
ip nat inside source static tcp 10.40.0.5 6882 interface Dialer1 6882
ip nat inside source static tcp 10.40.0.5 6881 interface Dialer1 6881
ip nat inside source static udp 10.40.0.5 4672 interface Dialer1 4672
ip nat inside source static tcp 10.40.0.5 4662 interface Dialer1 4662
ip nat inside source static tcp 10.40.0.10 3389 interface Dialer1 3390
ip nat inside source static tcp 10.40.0.5 3389 interface Dialer1 3389
ip nat inside source static 10.40.0.20 216.243.xxx.xx6 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
access-list 101 permit ip 10.40.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
line con 0
transport preferred all
transport output all
stopbits 1
line vty 0 4
session-timeout 60
privilege level 15
login
transport input all
scheduler max-task-time 5000
sntp server xxxxxxxx
sntp server xxxxxxxxxxxxx
end
  • WAN Routing and Switching
Re: 1:1 NAT used for Cisco CallManager
hi i will suggest you to remove all the ip address which are statically being natted from accesslist 101 and i suppose your public ip addresses are 216.243.xxx.xx4/30 so why you are using extendible command for CCM.
Kamlesh
How do you suggest i do that? I am still pretty new to all this. I tried creating a route map that referenced an ACL:
route-map NONAT permit 101
match ip address 101
ip nat inside source route-map NONAT interface Dialer1 overload
access-list 101 deny ip 216.243.xxx.xx4 0.0.0.4 any
This didnt make any improvement, but i may have configured it incorrectly as well.
I also dont understand what the extendable command does, i will look that up.
You just need to a deny statement in your access-list 101 which will select all the ip address which are being natted statically.
access-list 101 deny ip host 10.40.0.20
and remove extendible commmand from last statement i suppose route-map command is usefull when you want to do conditional natting out of multiple interfaces.
if you have any firewall than also you need to open the port for your CCM for incoming traffic from ip phone which wants to register to your CCM.
eve if you are using extendible natting than also you can use this but you need to cnfigure the incoming port 3389 and 3390 to your CCM ip address which is 10.40.0.20.
ip nat inside static tcp 10.40.0.20 3389 203.x.x.x6 3389 extendible.
843
